FreeNAS 8.3.0 (p1) My RAIDZ2 config has one disk that is going bad so I need to replace it.
The bad disk is the last one in the list, gptid/acc76f9b-804d-11e0-b1a2-0025903071b4, previously known as gpt/rz2_disk6 aka /dev/da5. Using WD's Advance Replacement procedure, I'm expecting to receive a replacement disk from them before I need to sent the disk to them. I'd prefer to use the current spare disk as replacement disk, and use the new disk as new spare. What's the best way to achieve all that? Is this doable from the WebUI or better done via the CLI ? Note: on the the WebUI the disks are still listed as da0-da6.
pool: rpool state: ONLINE scan: scrub repaired 4.50K in 14h19m with 0 errors on Sun Dec 30 01:13:00 2012 config: NAME STATE READ WRITE CKSUM rpool ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/ac3474a9-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 gptid/ac51b1c0-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 gptid/ac7236c2-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 gptid/ac8d49be-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 gptid/acaa342a-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 gptid/acc76f9b-804d-11e0-b1a2-0025903071b4 ONLINE 0 0 0 spares gpt/rz2_disk7 AVAIL
