Register for the iXsystems Community to get an ad-free experience
Basic Performance Tests
Tabmow
Hi All,
I have built my new FreeNAS Box and wanted to run a few standard performance tests before I put it into operation. Here are the specs of interest:
FreeNAS 9.1 Release x64:
SuperMicro X9SCL-+F Motherboard
Intel Core i3 3240
Amicroe DDR1333 ECC UDIMM 8GB x 2
WD30EFRX 3TB Red SATA3 64MB x 6
Sandisk 8GB Cruzer
PC Windows 8 x64:
Gigabyte X79-UD3 Motherboard
Intel Core i7-3820 @ 4.00GHz
Kingston DDR1666 8GB x 2
Sandisk 240 SSD - O/S Disk
Seagate 2TB ST2000DM001 - Data Disk
Network:
Billion BiPAC 7800N
All devices directly connected to switch
All parts on the FreeNAS box are brand new.
I went through and ran a badblocks tests using 2 passes with random blocks on all 6 individual disks.
Followed by smart long self tests on each of the 6 disks.
Configuration is as follows:
[root@freenas] ~# zpool status
  pool: tank
state: ONLINE
  scan: none requested
        NAME                                            STATE    READ WRITE CKSUM
        tank                                            ONLINE      0    0    0
          raidz2-0                                      ONLINE      0    0    0
            gptid/10e54aee-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
            gptid/11513510-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
            gptid/11bcd8f8-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
            gptid/122a390e-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
            gptid/1297c1b4-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
            gptid/13043d6b-04bf-11e3-9d21-0025907c4554  ONLINE      0    0    0
errors: No known data errors
[root@freenas] ~# zfs get compression
NAME  PROPERTY     VALUE     SOURCE
tank  compression  lz4       local
I ran some iperf testing first up using default window sizes of 64KB:
[root@freenas] ~# iperf -s
Server listening on TCP port 5001
TCP window size: 64.0 KByte (default)
[  4] local 192.168.1.200 port 5001 connected with 192.168.1.2 port 50960
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0-10.0 sec   842 MBytes   706 Mbits/sec
T:\Downloads\iperf-2.0.5-2-win32>iperf.exe -c freenas -p 5001 -f m
Client connecting to freenas, TCP port 5001
TCP window size: 0.06 MByte (default)
[  3] local 192.168.1.2 port 50960 connected with 192.168.1.200 port 5001
[  3]  0.0-10.0 sec   842 MBytes   707 Mbits/sec
I then ran some iperf tests using a window size of 128KB:
[root@freenas] ~# iperf -s -w 128k
TCP window size:  128 KByte
[  4] local 192.168.1.200 port 5001 connected with 192.168.1.2 port 51119
[  4]  0.0-10.0 sec  1.09 GBytes  937 Mbits/sec
T:\Downloads\iperf-2.0.5-2-win32>iperf.exe -c freenas -p 5001 -f m -w 128k
TCP window size: 0.12 MByte
[  3] local 192.168.1.2 port 51119 connected with 192.168.1.200 port 5001
[  3]  0.0-10.0 sec  1118 MBytes   938 Mbits/sec
As you can see, a window size of 128K is pretty much saturating my GB link. I can show this by pushing more threads through iperf to see whether I can get any higher Bandwidth:
[  4] local 192.168.1.200 port 5001 connected with 192.168.1.2 port 51406
[  5] local 192.168.1.200 port 5001 connected with 192.168.1.2 port 51407
[  4]  0.0-10.0 sec   562 MBytes   471 Mbits/sec
[  5]  0.0-10.0 sec   562 MBytes   471 Mbits/sec
[SUM]  0.0-10.0 sec  1.10 GBytes   942 Mbits/sec
T:\Downloads\iperf-2.0.5-2-win32>iperf.exe -c freenas -p 5001 -f m -w 128k -P 2
[  4] local 192.168.1.2 port 51407 connected with 192.168.1.200 port 5001
[  3] local 192.168.1.2 port 51406 connected with 192.168.1.200 port 5001
[  3]  0.0-10.0 sec   562 MBytes   471 Mbits/sec
[SUM]  0.0-10.0 sec  1124 MBytes   942 Mbits/sec
As you can see the SUM above is roughly the same so I know that my network throughput is pretty much at optimum speeds. I ran a lot of the above tests multiple times which produced the same result with little variance.
Next, I decided to start off with some base dd benchmarks.
[root@freenas] ~# dd if=/dev/zero of=/mnt/tank/testfile bs=4M count=10000
10000+0 records in
10000+0 records out
41943040000 bytes transferred in 20.669191 secs (2029254060 bytes/sec)
[root@freenas] ~# dd if=/dev/zero of=/mnt/tank/testfile2 bs=1048576
500854+0 records in
500853+0 records out
525182435328 bytes transferred in 229.041710 secs (2292955440 bytes/sec)
The second dd pass ran for about 5 minutes. I'm open to running some more tests if anyone has any ideas or wants me to try and benchmark my system in any other way. Once I get past these standard tests I will then run the different performance tests against my proper workload, mostly CIFS from my PC.
Cheers,
Tabmow
Hey! You got it working. Good for you. :)
You must be using compression, hence the bogus 2GB/sec+ to/from your zpool with the dd test.
Tabmow
Yeah I realised it wasn't really a correct test of the actual disk speeds.
Here are the same tests ran with compression off:
10000+0 records in
10000+0 records out
41943040000 bytes transferred in 98.646891 secs (425183597 bytes/sec)
276597+0 records in
276596+0 records out
290031927296 bytes transferred in 713.356649 secs (406573525 bytes/sec)
Here are some read tests:
[root@freenas] ~# dd of=/dev/zero if=/mnt/tank/testfile bs=4M count=10000
10000+0 records in
10000+0 records out
41943040000 bytes transferred in 102.292067 secs (410032187 bytes/sec)
[root@freenas] ~# dd of=/dev/zero if=/mnt/tank/testfile2 bs=1048576
243447+0 records in
243447+0 records out
255272681472 bytes transferred in 655.343970 secs (389524728 bytes/sec)
That looks about right. That's about what I get on a similar zpool to yours.
Freitag
hmm wenn ich das ausführ bekomme ich das
[root@storage-nas]# dd of=/dev/zero if=/mnt/vms-storage2/dump/ bs=1048576
0+1 records in
0+1 records out
2 bytes transferred in 0.000027 secs (74235 bytes/sec)
[root@storage-nas]#
