J. Greg Williams
- Sep 23, 2013
I'm trying to figure out why my FreeNAS box is stuck at 100mbit.
It's a stock HP N54L with 8gb of unbuffered ECC memory. This uses a Broadcom chip which I've read was an issue on FreeNAS in the past (version 0.7).
netperf shows this:
If the broadcom chip is still a known problem I'll pick up an Intel NIC and be done with it (suggestions welcome). Otherwise, if anyone has suggestions on what I can do to fix it given the existing hardware I'd be very happy for some tips.
Thanks,
Greg
bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f0000-0xfe9fffff irq 18 at device 0.0 on pci2
bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5784 10/100/1000baseT PHY> PHY 1 on miibus0
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
- All lights show gigabit between my laptop and the FreeNAS box connected to an Airport Extreme.
- There are no errors in the messages log. (Although this has stopped updating as of my update to 9.2.1.1-RELEASE)
- I am only running IPv4 although DUMMYNET seems to have initialized it (is this between communication between jails?)
- I've swapped cables to the NAS with a known good cable.
[totally@freenasty ~]$ ifconfig -a
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 28:92:4a:36:09:56
inet 10.0.1.11 netmask 0xffffff00 broadcast 10.0.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
netperf shows this:
[totally@freenasty ~]$ netperf
TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost () port 0 AF_INET : histogram : interval : dirty data : demo
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
65536 32768 32768 10.00 7814.72
iperf shows this:[totally@freenasty ~]$ iperf -c 10.0.1.5 -i 1
Client connecting to 10.0.1.5, TCP port 5001
TCP window size: 32.5 KByte (default)
[ 3] local 10.0.1.11 port 15075 connected with 10.0.1.5 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 1.0- 2.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 2.0- 3.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 3.0- 4.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 4.0- 5.0 sec 11.1 MBytes 93.3 Mbits/sec
[ 3] 5.0- 6.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 6.0- 7.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 7.0- 8.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 8.0- 9.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 9.0-10.0 sec 11.1 MBytes 93.3 Mbits/sec
[ 3] 0.0-10.0 sec 112 MBytes 94.2 Mbits/sec
Thanks,
Greg
