Is the Broadcom chip still a problem with FreeNAS?
I'm trying to figure out why my FreeNAS box is stuck at 100mbit.
It's a stock HP N54L with 8gb of unbuffered ECC memory. This uses a Broadcom chip which I've read was an issue on FreeNAS in the past (version 0.7).
bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f0000-0xfe9fffff irq 18 at device 0.0 on pci2
bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5784 10/100/1000baseT PHY> PHY 1 on miibus0
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
  • All lights show gigabit between my laptop and the FreeNAS box connected to an Airport Extreme.
  • There are no errors in the messages log. (Although this has stopped updating as of my update to 9.2.1.1-RELEASE)
  • I am only running IPv4 although DUMMYNET seems to have initialized it (is this between communication between jails?)
  • I've swapped cables to the NAS with a known good cable.
ifconfig -a shows:
[totally@freenasty ~]$ ifconfig -a
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 28:92:4a:36:09:56
inet 10.0.1.11 netmask 0xffffff00 broadcast 10.0.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
netperf shows this:
[totally@freenasty ~]$ netperf
TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost () port 0 AF_INET : histogram : interval : dirty data : demo
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
65536 32768 32768 10.00 7814.72​
iperf shows this:
[totally@freenasty ~]$ iperf -c 10.0.1.5 -i 1
Client connecting to 10.0.1.5, TCP port 5001
TCP window size: 32.5 KByte (default)
[ 3] local 10.0.1.11 port 15075 connected with 10.0.1.5 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 1.0- 2.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 2.0- 3.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 3.0- 4.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 4.0- 5.0 sec 11.1 MBytes 93.3 Mbits/sec
[ 3] 5.0- 6.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 6.0- 7.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 7.0- 8.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 8.0- 9.0 sec 11.2 MBytes 94.4 Mbits/sec
[ 3] 9.0-10.0 sec 11.1 MBytes 93.3 Mbits/sec
[ 3] 0.0-10.0 sec 112 MBytes 94.2 Mbits/sec
If the broadcom chip is still a known problem I'll pick up an Intel NIC and be done with it (suggestions welcome). Otherwise, if anyone has suggestions on what I can do to fix it given the existing hardware I'd be very happy for some tips.
Thanks,
Greg
jgreco
Resident Grinch
Not generally, but looks like something is amiss for you. You sure the laptop is actually linked at 1000? Guessing maybe not.
Yes, as sure as I can be.
From my laptop:
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV>
ether 68:5b:35:9d:98:a9
inet6 fe80::6a5b:35ff:fe9d:98a9%en0 prefixlen 64 scopeid 0x4
inet 10.0.1.5 netmask 0xffffff00 broadcast 10.0.1.255
nd6 options=1<PERFORMNUD>
media: autoselect (1000baseT <full-duplex,flow-control,energy-efficient-ethernet>)
status: active
  • Link light shows gigabit
  • I am able to scp a 2.4GB file to another computer on the gigabit network at roughly 57MB/s
Good suggestion. I removed the cable from the switch and plugged it directly into my laptop. (it auto switches to crossover so I don't need a separate cable).
iperf shows this:
[totally@freenasty /mnt/Hitachi/syslog/log]$ iperf -c 10.0.1.5 -i 1
[ 3] local 10.0.1.11 port 22241 connected with 10.0.1.5 port 5001
[ 3] 0.0- 1.0 sec 111 MBytes 934 Mbits/sec
[ 3] 1.0- 2.0 sec 112 MBytes 943 Mbits/sec
[ 3] 2.0- 3.0 sec 112 MBytes 942 Mbits/sec
[ 3] 3.0- 4.0 sec 112 MBytes 941 Mbits/sec
[ 3] 4.0- 5.0 sec 112 MBytes 942 Mbits/sec
[ 3] 5.0- 6.0 sec 112 MBytes 942 Mbits/sec
[ 3] 6.0- 7.0 sec 112 MBytes 936 Mbits/sec
[ 3] 7.0- 8.0 sec 112 MBytes 942 Mbits/sec
[ 3] 8.0- 9.0 sec 112 MBytes 942 Mbits/sec
[ 3] 9.0-10.0 sec 112 MBytes 942 Mbits/sec
[ 3] 0.0-10.0 sec 1.09 GBytes 940 Mbits/sec
After tracing some cables I discovered one connecting two switches was only doing so at 100Mbit, My previous test was against a machine on the same switch. Thanks for suggesting the obvious. I appreciate the help and it's good to know that the broadcom drivers are fine.
