OK, I have 2 FreeNAS devices which have been running smoothly for a couple of months. Both are running 8.0.3 Release 64-bit
Systems are identical (Intel i5, 16G RAM, 4 2TB drives).
One is visible to the Manufacturing floor, the 2nd is a pseudo "Hot" backup which is RSync'd every 15 minutes. (If anything ever happens to the first, the Manufacturing shifts can be quickly returned to production using the 'clone').
Suddenly today, I found that I could no longer access one of the devices using the Web GUI. I was greeted with a rather blunt but obscure error message:
Uhandled Exception: An Unhandled exception was thrown by the application.
Fantastic!.... this is about as informative as saying "ERROR: There was an error detected"
(Honestly, who writes these messages?!?)
So, I go to the console and see multiple lines of errors (2 identical lines which directly correlate with how many times I tried to connect to the server via the WebGUI) each line says:
/: bad dir ino 78512 at offset 24: mangled entry
All other aspects of the system appear to be running properly. The Rsync jobs are still actively being handled and data can still be read or written to the system.
zpool status reports no known errors and shows all drives.
So.... is the "bad dir" reference referring to the USB drive? and implying that it has become corrupted?
Would that explain why my GUI has suddenly died, but why everything else still works? or should I be concerned and start preparing for an immanent drive failure?
All help is appreciated.
