I do snapshot replication to a backup volume in the same FreeNAS box. I don't think it is significantly more risky than backing up to another box in the same house, and I can live with it.
That's a good question, and I hope someone more knowledgeable than I can answer. But I imagine it's the same as with any volume: just put the member disks in the system, and import the volume. You shouldn't even need the same configuration I would think.If the system ever crashes, how do I reattach the backup volume and any other drives (currently 6 X 2TB in Z2) to a new FreeNAS box? Do I simply save the config and upload again to a new system and attach original hard drives again to the new machine?
I think this depends on the "crash". If the system is a total loss i.e. flood or fire, you would build a new system, install FreeNAS (same version), build the new pool, ZFS send the backup snapshot(s) over to the new pool and restore the config... At least that would be my approach. I guess I have never tested this and I should. Document the process and print it to store with the backup.If the system ever crashes, how do I reattach the backup volume and any other drives (currently 6 X 2TB in Z2) to a new FreeNAS box? Do I simply save the config and upload again to a new system and attach original hard drives again to the new machine?
If it's strictly backup from one source. Start with 8GB and see how it goes. I suspect it will be fine. As this wont be a "hot" server, don't concern yourself with with ARC stats, memory usage, or CPU too much. As long as its as fast as you need for long writes, its fine.Are the RAM requirements for Backup Freenas box the same ?
I mean if the backup box is just a sleeping & wake & backup and nothing else => 1 GB of RAM for Each Physical TB of Storage ? 8GB minimum ?
This sounds like an interesting proposition--I'd like to hear how this goes once you get working on it.Personally I’m going to try and get my hands on a few Odroid-HC2 this winter and set up any supported *nix flavor that also comes with ZFS and use as a replication target.
There are a bunch listed here: https://www.hardkernel.com/main/distributor.phpneed a eu retailer
smartctl
, so you need to feed it -d sat
to tell it the device type. apt
.Setting up zfs-dkms (0.7.5-1ubuntu16.3) ... Ok, aborting, since ZFS is not designed for 32-bit kernels.
Some risks:snapshot replication to a backup volume in the same FreeNAS box. I don't think it is significantly more risky than backing up to another box in the same house, and I can live with it.
