Backing Up Metadata of Encrypted Pool
Mr_N
Could anyone assist me with my attempt to backup my geli metadata as mentioned in this thread?
https://forums.freenas.org/index.ph...gle-freenas-primary-storage.17316/#post-93073
My drives are da0 -> da5 so the command dusan mentioned needed adjustment...
I thought if i just use the following and manually name the files with the serial copied from the 'view disks' screen of the FreeNAS GUI as follows it should work:
geli backup da0 serial_for_da0.eli
geli backup da1 serial_for_da1.eli
etc
but all i got was the error msg:
geli: MD5 hash mismatch: not a geli provider?
so what am i doing wrong?
I tried it using da0p2 / da1p2 / da2p2 etc and got no error msg and a bunch of 512 byte files, how do i know if it worked?
Mr_N
No the geli meta data as described in the thread i linked to...
Mr_N
Nup still not sure if ive backed it up properly or not, I mean i've backup up something lol if only dusan was still around the forums to lend some expertise :)
