shnurov
 - Jul 22, 2015
I've gotten as far as the 'Rsync Task' section in the guide.
Now I'm getting the following error trying to 'save' the task.
I've researched the question and went backwards step by step - making sure I've followed everything to the dot.
Seems fine - but there are errors.
Then I found that I can call rsync manually to get it going.
It still asks me for a password (ssh key authentication doesn't work) and then errors start popping up.
Where did I mess up...
I'm on the same local network.
Going from a FreeNAS box (FreeNAS-11.2-U7) to a Synology DS416play (running DSM 6.2.2-24922 Update 4).
Disconnect Error[ error code 14 ]
rsync -avz -e ssh rsync@192.168.1.168:volume1/backup /mnt/lz1-3tb/Aux/
rsync@192.168.1.168's password: receiving incremental file list ERROR: module is write only rsync error: syntax or usage error (code 1) at main.c(782) [sender=3.0.9] rsync: connection unexpectedly closed (110 bytes received so far) [Receiver] rsync error: error in rsync protocol data stream (code 12) at io.c(226) [Receiver=3.1.3]
