AWS Glacier on freenas
playboy71322
All I see is Amazon S3 so Amazon S3 Glacier isn't supported? Does anyone have glacier working or can provide some help so I can get mine working? Thanks.
DrKK
FreeNAS Generalissimo
I use Glacier, but I feed it from a Windows program ("fastglacier") on a windows box to which are mounted my FreeNAS shares...
I am not aware of anyone successfully using Glacier from FreeNAS itself.
playboy71322
man that sucks, i feel that it should be built in....ill try your way and see if it accomplishes my goal
Corey Clamp
Glacier is a storage tier/class in AWS S3. With that said, you can manage which storage class AWS uses to store your data using a transition rule in a bucket lifecycle policy. Using the lifecycle policy allows you to specify which objects to send to Glacier based on prefix (name), tags, age, etc... You can also expire/delete objects using the policy.
https://docs.aws.amazon.com/AmazonS3/latest/user-guide/create-lifecycle.html
