Available Plugins won't list
ARAMP1
I just installed 11.2-U3 (from 11.1). I figured I'd install the Plex plugin and start playing around with the new (new to me, anyway) UI. I went to available Plugins and get this error. Any ideas?
ASRock Rack C236 WSI motherboard
Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz CPU
32Gb memory
Turgin
Have you configured DNS servers and default gateway under Network -> Global Configuration?
Turgin
Assuming those are valid addresses for your network that's probably not your problem then. I had neglected to set nameservers on a new install and had problems similar to yours so I thought I'd mention it.
Jailer
Not strong, but bad
I wonder if this has anything to iX moving to a new CDN recently. I'd file a bug report for it.
ARAMP1
Well, I decided to go ahead and do a fresh install of FreeNAS 11.2 and I'm getting the same error.
OneT
I've been through most if not all of the posts related to this problem. I've installed (successfully I think) the new 11.2. I've updated all the network configurations, such as: Default Gateway, NameServers, etc. I can successfully ping google.com from my Jail shell and from my FreeNAS shell with no problems. Any other ideas, or is this a bug?
From Jail:
root@PlexMediaServer_2:~ # ifconfig
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 0c:c4:7a:ca:16:5d
hwaddr 02:ff:d0:00:06:0b
inet 172.16.0.136 netmask 0xffffff00 broadcast 172.16.0.255
nd6 options=1<PERFORMNUD>
status: active
groups: epair
From FreeNAS:
groups: lo
options=8<VLAN_MTU>
status: active
groups: epair
Sorry if I missed something... any suggestions?
OneT
I seemed to get this working. At first, I thought I had a firewall issue. But no.
I rebooted a few times, tried DHCP, then went back to more static addressing.
I think it was related to the system (FreeNAS or Jail - don't know which) not finding the DNS (hostname server).
I did create static routes to automatically find 8.8.8.8, 8.8.4.4. this might have been the trick.
I will post my config if others request it.
OneT
adding the rest of the screen shots....
