Auto Import Raid1 GEOM
msrdn767
I am running FreeNAS 8.0.1 release version and try to Auto import a RAID 1 from FreeNAS 0.7.2.
I always see the following error (see attachment)
Thank you for your help.
patrick0525
I plan to migrate from 0.7.2 to 8.1 for my raid5 Freenas system.
I tested it on VirtualBox by creating a 0.7.2 & 8.0.1 VirtualMachines
#1 on 0.7.2 ssh command line 'zpool list' identifies my pool name 'tank'
on 0.7.2 ssh command line 'zpool export tank'
shutdown 0.7.2 VM
#2 on 8.0.1 Storage->Volume _> Auto Import Volume
Import the exported Zpool
Everything worked! The *.MP3 file stored on 0.7.2 was accessible on 8.0.1
bagarnx
I have the exact same problem, the mirror disks won't import.
Could this be a bug in 8.0.1?
Is it possible to mount just one of the disks in a RAID1 configuration as a single drive in freenas?
I tried importing just one of the disks, but the same error appears.
File system of the disks are UFS.
Any ideas?
bagarnx
Tried FSCK:ing the drives, and again importing them. The same error.
Really no one with an idea?
I assume it is a UFS geom mirror you're trying to import? There's a bug open for that which I think is what you're hitting here:
http://support.freenas.org/ticket/829
I'm also hitting this bug. Hopefully it'll get fixed soon! I did try to work on a patch yesterday, but I don't really have enough context of how this all fits together to make much progress and I don't have a whole lot of time at the moment to devote to it.
The bug is now marked as fixed, but does anyone know when this is likely to make it in to a release?
