Authentication with Azure Active Directory
Is FreeNAS capable of Authenticating with a cloud-only Azure Active Directory?
I have scoured the usual online sources and have not had any luck.
If there are any resources or gems of wisdom, I would sure welcome them.
Thanks!
seblie
Thanks @plsuh for sharing your writeup! Are there any updates on how to properly connect FreeNAS and Azure AD? Something more official from TrueNAS?
plsuh
Nothing that I'm aware of.
Be aware that doing this can be expensive -- Azure AD and Azure VPN Gateway are $100 USD each per month, plus data charges plus what not runs to $2500 USD per year. I have set up a local AD domain controller and I'm preparing to implement Azure AD Connect to implement sync. I'm being very cautious since it's a mostly one-way sync (local DC to cloud) although password changes can be sync'ed back. I don't want to wipe any cloud accounts that are already established.
Also, I'm cross-linking the other thread on this that I started earlier. It's probably best to put any additional posts on that thread.
