Attempting downgrade to 9.3xx 'read-only' error
vv111y
Something went wrong with Corral. But attempting to rollback to one of the previous releases keeps getting the same error (for any release):
on the console, it is always 'can't access a /var/log file, file system is read-only',
-- at least those are the ones I managed to see.
I have a screenshot where I attempted to import the pool.
I will do a clean re-install from stick, but this is a loss of what should be a useful feature. Any way to make rollbacks work?
Thanks.
D
dlavigne
Guest
How are you rolling back? By booting into a previous boot environment from the boot menu?
vv111y
Yes
Sent from my SM-G900W8 using Tapatalk
D
dlavigne
Guest
Hmm, that's a pretty old version...
Just to clarify, you didn't restore your Corral config on this system?
Do you have any better luck if you install the latest 9.10-STABLE to a different stick? If that imports the pool, you could then try restoring your saved 9.3 config.
vv111y
I couldn't restore configuration because of same prob - read only.
Version - yeah I kept going back farther to avoid prob. Always same thing.
I have my prev 9.3 configuration saved so that is ok ( I hope)
vv111y
Great
Clean install , not repair, of freenas. Importing pool
Exact. Same. Problem.
Why?
vv111y
And I can't upload configuration either.
I give up. Far more time than I can afford. I have no idea what to do.
vv111y
I'm installing on new usb. Will report in a few minutes
vv111y
9.3-stable-201502162250
vv111y
New usb. Bios reset.
Can't import pool
Can't upload configuration
Can't get update server ( err 8 host name or serve name not provided)
vv111y
Manual config static IP & Google dns servers
vv111y
??? Wait. Pool shows up even though it gave same error
vv111y
The pool was up. I uploaded old config file. Reboot.
Problems galore.
Console: same error messages keep cycling - error opening file for writing; filename ='/var/log/xxxx', file system is read only #30.
That config was an older one I know was perfectly fine.
Which file system? Isn't it only in RAM? is any of the pool used?
Console is non-responsive too
Richard J2
I also did a fresh install following a range of roll back errors.
Sent from my SM-G955F using Tapatalk
Why are you using a two-year-old version of FreeNAS? 9.10 is very stable and has fixed a lot of bugs. If you were using a VirtualBox jail, and want to do so again, use 9.10.1-U4; otherwise, use the latest 9.10.2.
vv111y
Does that make a difference with these problems? Don't see how.
Sure I'll try a newer version
It could. For one thing, as I already mentioned, many bugs have been fixed in the 9.x series over the past two years. Second, over time, new ZFS feature flags have been introduced. Especially if you upgraded your pool under FN10, they could prevent it from importing under 9.3.
