Hi All,
My machine has been off for a while because I was out of town. I turned it on and CAM Status: ATA Status Errors started showing up.
This repeats a while. I tried a smart test on all drives. ADA4 had issues:
And then..
Is the drive dead? Should I turn off the whole machine until I can order a replacement? It didn't have issues before as far as I know. Thanks. Very worried
Jul 4 21:58:18 freenas (ada4:ahcich13:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 80 03 40 40 00 00 00 01 00 00 Jul 4 21:58:18 freenas (ada4:ahcich13:0:0:0): CAM status: ATA Status Error Jul 4 21:58:18 freenas (ada4:ahcich13:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) Jul 4 21:58:18 freenas (ada4:ahcich13:0:0:0): RES: 41 40 b0 03 40 40 00 00 00 00 00 Jul 4 21:58:18 freenas (ada4:ahcich13:0:0:0): Retrying command
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Jul 4 22:30:34 2020 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (39060) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 392) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 40
3 Spin_Up_Time 0x0027 181 181 021 Pre-fail Always - 5908
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 43
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 1
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 22869
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 43
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 259
194 Temperature_Celsius 0x0022 119 111 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 6 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 6 occurred at disk power-on lifetime: 22869 hours (952 days + 21 hours)
ER ST SC SN CL CH DH
04 61 00 00 00 00 40
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
e0 00 00 00 00 00 40 08 1d+17:33:23.352 STANDBY IMMEDIATE
b0 d5 01 01 4f c2 40 08 1d+17:29:55.339 SMART READ LOG
b0 d5 01 06 4f c2 40 08 1d+17:29:55.338 SMART READ LOG
Error 5 occurred at disk power-on lifetime: 22850 hours (952 days + 2 hours)
04 61 10 90 02 40 40 Device Fault; Error: ABRT 16 sectors at LBA = 0x00400290 = 4194960
c8 00 10 90 02 40 40 08 23:04:33.130 READ DMA
c8 00 10 90 02 40 40 08 23:04:33.129 READ DMA
Error 4 occurred at disk power-on lifetime: 22850 hours (952 days + 2 hours)
Error 3 occurred at disk power-on lifetime: 22850 hours (952 days + 2 hours)
Error 2 occurred at disk power-on lifetime: 22850 hours (952 days + 2 hours)
# 1 Extended offline Completed without error 00% 22823 -
# 2 Short offline Completed without error 00% 22744 -
# 3 Short offline Completed without error 00% 22576 -
# 4 Extended offline Completed without error 00% 22487 -
# 5 Short offline Completed without error 00% 22408 -
# 6 Short offline Completed without error 00% 22168 -
# 7 Extended offline Completed without error 00% 22080 -
# 8 Short offline Completed without error 00% 22001 -
# 9 Short offline Completed without error 00% 21833 -
#10 Extended offline Completed without error 00% 21744 -
#11 Short offline Completed without error 00% 21666 -
#12 Short offline Completed without error 00% 21474 -
#13 Extended offline Completed without error 00% 21385 -
#14 Short offline Completed without error 00% 21306 -
#15 Short offline Completed without error 00% 21138 -
#16 Extended offline Completed without error 00% 21050 -
#17 Short offline Completed without error 00% 20971 -
#18 Short offline Completed without error 00% 20731 -
#19 Extended offline Completed without error 00% 20642 -
#20 Short offline Completed without error 00% 20563 -
#21 Short offline Completed without error 00% 20395 -
1 0 0 Not_testing
2 0 0 Not_testing
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
And then..
CRITICAL: July 4, 2020, 9:58 p.m. - Device: /dev/ada4, 4 Currently unreadable (pending) sectors CRITICAL: July 4, 2020, 10:04 p.m. - The volume jvol state is DEGRADED: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
