BarefootWoodworker
- Feb 22, 2017
Long time reader, first time poster on the forums. Mainly, I'm posting because I got an email alert that my FreeNAS iSCSI array had degraded, ATA error counts had increased, and I was wondering how my (fairly new) 2TB Red Pros were biting the dust already.
I did some research and saw the helpful thread above about power needs. After reading that, I realized I was a lazy geek and figured 550W would be enough for 8 3.5" drives and 4 2.5" drives on an E5 2603 with 32GB of RAM (4 sticks). Bad me. (Don't worry, I'll whip myself with some SATA cables lying around).
That being said, here's the console output:
And here's the smart output:
Now, I'm hoping the drive is okay. To me, it looks okay, but I'd prefer someone here that's actually breathing FreeNAS and storage knowledge who can say "Yes, idiot. You underpowered your 12 drives, the ATA error you encountered was due to a power sag, and when you get a 1000w PSU, you should be fine".
TIA. The forums have been super helpful for me putting together this box, except for this little part I decided to gloss over, and that's wholly my bad.
edit:
Reset /dev/da5 in zpool and resilvered the drive. . .looks okay for now.
Feb 22 15:48:09 iscsi (da5:mps0:0:5:0): CAM status: SCSI Status Error Feb 22 15:48:09 iscsi (da5:mps0:0:5:0): SCSI status: Check Condition Feb 22 15:48:09 iscsi (da5:mps0:0:5:0): SCSI sense: NOT READY asc:4,0 (Logical unit not ready, cause not reportable) Feb 22 15:48:09 iscsi (da5:mps0:0:5:0): Error 5, Retries exhausted Feb 22 15:48:48 iscsi mps0: mpssas_prepare_remove: Sending reset for target ID 5 Feb 22 15:48:48 iscsi da5 at mps0 bus 0 scbus0 target 5 lun 0 Feb 22 15:48:48 iscsi da5: <ATA WDC WD2002FFSX-6 0A81> s/n WD-WMC6N0D22SWP detached Feb 22 15:48:48 iscsi GEOM_ELI: Device da5p1.eli destroyed.mps0: Feb 22 15:48:48 iscsi Unfreezing devq for target ID 5 Feb 22 15:48:48 iscsi GEOM_ELI: Detached da5p1.eli on last close. Feb 22 15:48:48 iscsi (da5:mps0:0:5:0): Periph destroyed Feb 22 15:49:26 iscsi mps0: SAS Address for SATA device = a6944826a8c7ca85 Feb 22 15:49:26 iscsi mps0: SAS Address from SATA device = a6944826a8c7ca85 Feb 22 15:49:26 iscsi da5 at mps0 bus 0 scbus0 target 5 lun 0 Feb 22 15:49:26 iscsi da5: <ATA WDC WD2002FFSX-6 0A81> Fixed Direct Access SPC-4 SCSI device Feb 22 15:49:26 iscsi da5: Serial Number WD-WMC6N0D22SWP Feb 22 15:49:26 iscsi da5: 600.000MB/s transfers Feb 22 15:49:26 iscsi da5: Command Queueing enabled Feb 22 15:49:26 iscsi da5: 1907729MB (3907029168 512 byte sectors) Feb 22 16:23:14 iscsi smartd[39957]: Device: /dev/da5 [SAT], ATA error count increased from 0 to 1 Feb 22 16:23:14 iscsi smartd[39957]: Device: /dev/da5 [SAT], ATA error count increased from 0 to 1
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD2002FFSX-68PF8N0 Serial Number: WD-WMC6N0D22SWP LU WWN Device Id: 5 0014ee 0598b0d0f Firmware Version: 81.00A81 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Feb 22 21:18:24 2017 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 221) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 4 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 649 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 4 16 Unknown_Attribute 0x0022 000 200 000 Old_age Always - 9667034759 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 2 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2 194 Temperature_Celsius 0x0022 117 115 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 643 hours (26 days + 19 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 41 10 48 64 6d 40 Error: Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 628 - # 2 Extended offline Completed without error 00% 514 - # 3 Short offline Completed without error 00% 460 - # 4 Short offline Completed without error 00% 292 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
edit:
pool: iSCSI state: ONLINE scan: resilvered 1.42G in 0h1m with 0 errors on Wed Feb 22 21:30:28 2017 config: NAME STATE READ WRITE CKSUM iSCSI ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/8ccffd25-e420-11e6-90db-001517b8e52a ONLINE 0 0 0 gptid/8d836b19-e420-11e6-90db-001517b8e52a ONLINE 0 0 0 gptid/8e26bd6b-e420-11e6-90db-001517b8e52a ONLINE 0 0 0 gptid/8ec8c9d6-e420-11e6-90db-001517b8e52a ONLINE 0 0 0 gptid/8f6ca59a-e420-11e6-90db-001517b8e52a ONLINE 0 0 0 gptid/90104042-e420-11e6-90db-001517b8e52a ONLINE 0 0 0
