spurdo1337
- Feb 23, 2017
Hi everyone
Got this nice little warning
Should i do anything about this?
Thanks in advance
![EqP7ts3.png](https://i.imgur.com/EqP7ts3.png)
Thanks in advance
root@freenas:~ # smartctl -a /dev/da1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: <redacted> LU WWN Device Id: 5 000cca 254d02113 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Feb 12 16:46:57 2018 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1484) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 112 3 Spin_Up_Time 0x0007 169 169 024 Pre-fail Always - 406 (Average 371) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 73 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 098 098 000 Old_age Always - 14676 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 73 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1211 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1211 194 Temperature_Celsius 0x0002 162 162 000 Old_age Always - 37 (Min/Max 21/48) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 14660 hours (610 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 41 00 00 00 00 00 Error: UNC at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 e8 28 f8 46 53 40 00 6d+03:54:25.202 READ FPDMA QUEUED 60 00 20 f8 45 53 40 00 6d+03:54:16.911 READ FPDMA QUEUED 60 00 18 f8 44 53 40 00 6d+03:54:16.911 READ FPDMA QUEUED 60 00 10 f8 43 53 40 00 6d+03:54:16.911 READ FPDMA QUEUED 60 00 08 f8 42 53 40 00 6d+03:54:16.861 READ FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 14676 - # 2 Short offline Completed without error 00% 14576 - # 3 Short offline Completed without error 00% 14564 - # 4 Short offline Completed without error 00% 14409 - # 5 Short offline Completed without error 00% 14397 - # 6 Short offline Completed without error 00% 14337 - # 7 Short offline Completed without error 00% 14325 - # 8 Short offline Completed without error 00% 14168 - # 9 Short offline Completed without error 00% 14156 - #10 Short offline Completed without error 00% 14000 - #11 Short offline Completed without error 00% 13988 - #12 Short offline Completed without error 00% 13832 - #13 Short offline Completed without error 00% 13820 - #14 Short offline Completed without error 00% 13665 - #15 Short offline Completed without error 00% 13653 - #16 Short offline Completed without error 00% 13593 - #17 Short offline Completed without error 00% 13581 - #18 Short offline Completed without error 00% 13425 - #19 Short offline Completed without error 00% 13413 - #20 Short offline Completed without error 00% 13161 - #21 Short offline Completed without error 00% 12800 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
