Tinus Blaauw
- Mar 28, 2014
Hi Everybody,
HP N54L Server
16GB RAM (Initially, now only 8G - see below)
5x 4TB Seagate ST4000DM000 drives
1x 30GB USB stick
OK, so where do I start?
Got this brand new a couple of days ago - installed 9.2.1.3, just to find out there is a problem with transferring of the ZFS snapshots through SCP - known bug - so downgraded to 9.2.1.2
So, finally, ZFS pools and everything has bee configured, replication job from another machine was running perfectly. Every now and again, the WebGUI would stop to respond. Had to SSH into the box and restart 2 processes... njinx and djenga? - not sure about the names now any more.
Anyway, the WebGUI non responsiveness became more apparent the past 24 hours, until this morning where it did not respond at all. Upon plugging in a screen on the server, the machine appeared to be in a rebooting frenzy, every time giving a kernel panic.
First deduction - probably just a installation that went bad - so reinstalled. Same endless !@#!@$ loop with the kernel panic.
To cut a long story short - found the original 2x8GB DIMM's had a manufacturing fault or something, so replaced that with 2x4GB's. Also tried VARIOUS flavours of 'cooked' bios's --- in order to get the onboard SATA port on full speed (3.0 Gbps).
Whenever the machine now boots, it FREQUENTLY hangs at some sort of mDNS thing - sorry for the lack of the exact name - but concentration is not that high anymore, as I have been battling with this machine since 8am, and it's not almost midnight!
I have redownloaded freenas images, burnt new disks, etc. etc. etc. - same continous problem. I've changed everything possible EXCEPT for the physical server and hard drives (bear in mind the installation is onto a USB disk - and I have swopped those out too!)
Before starting this post, I switched on the server - and about a minute ago, it finally botted to the console setup screen again. So the better part of about 5 minutes where it 'hung' on the mDNS error.
To make things worse, I have an EXACT same machine (different BIOS, and different RAM), and it runs like a dream.
Any/all help appreciated!
Regards
Tinus
HP N54L Server
1x 30GB USB stick
Regards
Tinus
