Matthew Hinchliffe
- May 5, 2016
Hi
I am having a problem running FreeNAS once I have completed the installation to a USB stick.
I have created the installer USB from the FreeNAS-9.10-STABLE-201605021851.iso using Rufus and selecting ISO mode.
I am able to boot into the FreeNAS installer and I am able to select my 2nd USB drive as my target for the installation. The installation completes OK and then asks me to remove the installation media and reboot. Upon reboot I get the following error message :
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key
I have checked the target USB and it has a GPT partition and the installer USB has and MBR partition.
My USB sticks are:
Installation USB: SanDisk Ultra USB 3.0 16 GB
Target (OS) USB: HP v285 w 16 GB
I have tried swapping the drives so the installer is on the HP and Target is the Sandisk but still get the same error.
When I put the Target OS USB into my laptop, which is currently running Windows 10, it brings up the grub menu with the option for FreeNAS.
Finally, I did once get the OS to load on my intended machine, and was able to set up a Jail etc. But then when I rebooted I was presented with the Reboot and Select proper Boot device error.
My intended machine for FreeNAS was an work machine in the past running Windows 8 I think.
The FreeNAS box is intended for small scale file sharing on a non-critical home network.
My set up is as follows :
PC: Acer Aspire X3990
Processor: Intel Core i3-2120 3.3GHz
RAM: 8GB non-ecc - I am not sure the exact specs.
System BIOS: P01-B0L ( I flashed the original BIOS to this version)
2x Western Digital SATA hard drives.
I am wondered whether my hardware will support FreeNAS ? Hopefully, someone can help as I am running out of ideas.
My USB sticks are:
