ASUS PIKE 2208 problem
bormental
Doesn't work :-(
Enabled JBOD
root@freenas[~]# MegaCli "-AdpSetProp -EnableJBOD 1 -a0"
Adapter 0: Set JBOD to Enable success.
Exit Code: 0x00
Make Good
root@freenas[~]# MegaCli "PDMakeGood PhysDrv[6:0] -Force -a0"
Adapter: 0: Failed to change PD state at EnclId-6 SlotId-0.
Exit Code: 0x01
Make JBOD
root@freenas[~]# MegaCli "PDMakeJBOD PhysDrv[6:0] -a0"
Exit Code: 0x01
Attached dmesg and adapter info.
what shows?
MegaCli -PDList -a0
bormental
from adapter.txt
Supported PD Operations ================ Force Online : Yes Force Offline : Yes Force Rebuild : Yes Deny Force Failed : No Deny Force Good/Bad : No Deny Missing Replace : No Deny Clear : No Deny Locate : No Support Temperature : Yes NCQ : No Disable Copyback : No =========> Enable JBOD : No Enable Copyback on SMART : No Enable Copyback to SSD on SMART Error : Yes Enable SSD Patrol Read : No PR Correct Unconfigured Areas : Yes Enable Spin Down of UnConfigured Drives : Yes Disable Spin Down of hot spares : No Spin Down time : 30 T10 Power State : No
try to update the firmware, the adapter says it does not support JBOD for physical disks
for PIKE 2208
Supported PD Operations ================ Force Online : Yes Force Offline : Yes Force Rebuild : Yes Deny Force Failed : No Deny Force Good/Bad : No Deny Missing Replace : No Deny Clear : No Deny Locate : No Support Temperature : Yes NCQ : Yes Disable Copyback : No =========> Enable JBOD : Yes Enable Copyback on SMART : No Enable Copyback to SSD on SMART Error : Yes Enable SSD Patrol Read : No PR Correct Unconfigured Areas : Yes Enable Spin Down of UnConfigured Drives : Yes Disable Spin Down of hot spares : No Spin Down time : 30 T10 Power State : No
jotauve
from adapter.txt
for PIKE 2208
Sorry , updated adapter info and removed all old RAID used disks and put two never used on RAID disks. I'm using a PIKE 2108, not 2208.
Exit Code: 0x00
root@freenas[~]# MegaCli "-AdpAllInfo -aAll" > adapter.txt
root@freenas[~]# MegaCli "-PDList -a0" > pdlist.txt
Exit Code: 0x01
Now in this included adapter.txt got
Enable JBOD                             : Yes
  • adapter.txt
  • pdlist.txt
bormental
Exit Code: 0x00
Exit Code: 0x01
Enable JBOD                             : Yes
Drives are half the problem. The old configuration on the controller interferes.
