ASUS PIKE 2208 problem
bormental
Hi there! Recently put freenas at home. And periodically there is a problem, disks connected through Asus pike 2208 raid controller fall off.In the logs it says:
Sep 18 12:29:02 rpc-nas (da1:(da0:mrsas0:0:mrsas0:0:1:0:0): 0): Invalidating pack
Sep 18 12:29:02 rpc-nas Invalidating pack
Sep 18 12:29:02 rpc-nas da1 at mrsas0 bus 0 scbus0 target 1 lun 0
Sep 18 12:29:02 rpc-nas da1: <LSI MRROMB 3.24> s/n 0047d83c15288efd2400ed06c062ea00 detached
Sep 18 12:29:02 rpc-nas da0 at mrsas0 bus 0 scbus0 target 0 lun 0
Sep 18 12:29:02 rpc-nas da0: <LSI MRROMB 3.24> s/n 00ec3a7fce02e9e52400ed06c062ea00 detached
Sep 18 12:32:05 rpc-nas mrsas0: Internal command timed out after 180 seconds.
Sep 18 12:32:05 rpc-nas mrsas0: DCMD timed out after 180 seconds from mrsas_issue_blocked_cmd
Sep 18 12:32:05 rpc-nas mrsas0: DCMD opcode 0x1101000
Sep 18 12:32:18 rpc-nas devd: notify_clients: send() failed; dropping unresponsive client
Sep 18 12:32:42 rpc-nas zfsd: Consumer::EventsPending(): POLLHUP detected on devd socket.
the last two lines are repeated, the system hangs until forced reboot
prompt in what there can be a problem?
hardware
mb asus z8pe-d18
ram 98GB ecc
raid asus pike 2208
hdd ssd kingspec 720G mirror
from raid controller each disk is forwarded as virtual raid 0 consisting of the 1st disk. the trim controller does not pass because of this its slow work is observed, I am going to fix by means of over-provisioning of reservation of a place
Hi @bormental, sorry you're having issues.
You may already know this, but RAID controllers and FreeNAS is generally seen as a bad idea. At best they can obscure important disk information required to monitor disk health, such as smartctl, at worst they interfere with how the system communicates with the device and add their own layer of indirection and when the RAID controller fails you're unable to recover your pool even on perfectly good disks. FreeNAS uses zfs which likes direct, unmodified access to the disks.
The advice around these forums with respect to RAID controllers is to either flash them into IT mode or choose to not use the controller or don't use FreeNAS because doing so adds significant risk. In order to use IT mode you'd need to flash the controller.
For your specific case I can't say what is wrong. I would suggest you consider backing up your data and flashing your controller to IT mode or picking up a used controller off ebay to replace it. The time and little bit of money you'll spend doing this will be well repaid by a more stable system.
bormental
... you'll spend doing this will be well repaid by a more stable system.
Thank you for not staying away. Yes I am aware of problems of hardware RAID but while other way to use a large number of disks isn't present. Yes PIKE allows a variety of settings for the disk, including disk forwarding on the line. But smartctl will not work anyway, although partitioning remains the same with the controller and without it. I'll try to experiment with iron. Where can I read about IT mode? Thanks.
How many drives do you have? Your board has plenty of SATA ports, you could likely get by with a 50-60 dollar HBA to give you access to all the drives you need; if that isn't enough another 30-40 gets you an expander which dramatically increases the total possible drive count.
bormental
planned about 20. there are 14 sata connectors on the Board but only 6 work without PIKE, the other 8 only if the controller is on Board
PCIe NMVE is planned for L2ARC and ZIL. On the machine there will be a storage and virtual machines of 10-15 pieces
bormental
ASUS PIKE is essentially the same HBA working through PCIe. only the connector is unique :smile:
You could go with a traditional HBA then to power those extra drives. The advantage being you're using an IT mode HBA rather than any kind of hardware RAID. Though, I admit I am unfamiliar with the ASUS PIKE.
NVMe is a great choice for the ZIL; I'm not 100% sure if it is as important to have something so fast for an L2ARC. I only mention it if you're low on PCIe slots when all is said and done. The other option is to use a PCIe -> 2x M.2 in an 8x slot if that would save you an extra PCIe slot.
Like I said, I'm not super familiar with your specific hardware though so take my advice with a grain of salt. The biggest thing I would suggest though is to do whatever you can to avoid hardware raid and go with an HBA in IT mode.
bormental
seems the problem was hardware, reversed the shoelaces sata until glitch there is no
bormental
but to reflash PIKE all the same it is necessary on host sata. I will search for firmware
bormental
enabled jbod mode. That is all right. the drives are interchangeable with the hba controller. trim works. smart works
Hi @jotauve. I don't know how to do off-hand but I bet a quick search will turn something up. Did you get a chance to google "Asus PIKE 2108 flash to IT mode" or similar? If so, did nothing come up?
jotauve
Yes, i've done this search but all posts refers to PIKE 2008, not 2108
Ah, I see. I did a search and put the 2108 in quotes and found this pdf, not sure if it helps any or not.
bormental
I have a Asus server with PIKE 2108 card. How can i flash in IT mode? Thanks.
checking JBOD support:
megacli -AdpGetProp enablejbod -aALL
enable JBOD mode:
megacli -AdpSetProp EnableJBOD 1 -aALL
the latest version of firmware on asus.com
JBOD mode is supported by the standard firmware PIKE 2208 nothing else need to flash, for 2108 need to check
man megacli
jotauve
enable JBOD mode:
man megacli
Thanks
Using last firmware from ASUS
megacli -AdpSetProp EnableJBOD 1 -a0 -> JBOD Enabled
megacli PDMakeJBOD -PhysDrv[32:5] -a0 -> Failed to change PD state (same error after reboot)
Is the correct way?
bormental
Thanks
Is the correct way?
If you have previously configured raid on these disks, you will need to disassemble it, save the data. Look at the status of the disks, should be able to good - command megacli-PDMakeGood -PhysDrv[x:y] -Force -a0
jotauve
Doesn't work :-(
Enabled JBOD
root@freenas[~]# MegaCli "-AdpSetProp -EnableJBOD 1 -a0"
Adapter 0: Set JBOD to Enable success.
Exit Code: 0x00
Make Good
root@freenas[~]# MegaCli "PDMakeGood PhysDrv[6:0] -Force -a0"
Adapter: 0: Failed to change PD state at EnclId-6 SlotId-0.
Exit Code: 0x01
Make JBOD
root@freenas[~]# MegaCli "PDMakeJBOD PhysDrv[6:0] -a0"
Exit Code: 0x01
Attached dmesg and adapter info.
  • adapter.txt
  • dmesg.txt
