deadman36g
- Apr 4, 2015
I have a server built with an ASRock C2750D4I that recently begin giving me issues.
I want to share an email that I have sent to William at ASRock support to help define my problem. After extensive googling I see that William is excellent at ASRock support.
The email states...
If there is anyone here that can provide any additional support, I would most greatly appreciate it.
The email states...
I am reaching out to you for help with my C2750D4l board. I was referred to you by a message forum and hope you do not mind me emailing you. I have had my server set up since around April 2015 working pretty flawlessly. I accessed my server most recently on this past Sunday night, and when I tried to access it on Monday morning I noticed I had no network access to my server. This has happened a few times before (Once because my Hard Drive was so full it couldnt load the gui of my OS OpenMediaVault. Usually a quick reboot fixes this issue, but I rebooted and noticed the network connection never returned. I can access the server via IPMI interface and the remote control says ‘Host is powered off or in sleep mode’ I have disconnected all of Hard Drive except the one hosting my OS and the result is the same. I read the instructions you gave another individual with a similar problem and followed them 1. Remove RAM, insert one RAM stick into blue A1 slot 2. Clear the CMOS by holding down the case power button for 30 seconds without the power cable attached to the board and without the CMOS battery inserted 3. Put the power back in as well as the CMOS battery. Turn on the PSU (not the board), and wait until the green BMC LED starts to flash 4. Turn on the server board and check the Sensor Readings in Megarac web management console – Server Health, with the board turned on. After doing this, I am still receiving the ‘Host is powered off or in sleep mode’ message My servers specs are as follows case: SilverStone DS380B board: ASRock C2750D4I Mini ITX Server Motherboard FCBGA1283 DDR3 1600 / 1333 ram: Kingston 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1333 Server Memory Intel Model KVR13E9K2/16I psu: SILVERSTONE ST45SF 450W
