I see a lot of C2750 builds. What are the advantages of the C2750 build vs the 2550 build?
Is Freenas useful using more than 4 cores in regular loads and normal LAN speeds?
Not to say that the additional processing power might not be useful someday, but in the here and now the 8-core is an extreme amount of processing power for a FreeNAS box. ;)
Considering the ASRock C2550D4I has 12 SATA ports, low power, intel NIC (2x) and well supported by freenas it seems to me the ideal entry level board for freenas.
