Areca 1882 for ZFS
beardy
I can see some old posts from Cyberjock where he's had problems with Areca cards
e.g. https://www.ixsystems.com/community...single-lun-for-all-pass-through-drives.20048/
However, it seems it's now possible to get smartctl to read the areca data correctly nowddays, see below
Just wondering if anyone had more recent success. I'm not sure if it's possible to make ZFS aware of the smartctl data somehow? Just because I can see it I can't assume ZFS can. And maybe there's more to the story than just that
Is Cyberjock still around?
Hope this isn't too offensive but I may not end up using freenas on this one, but proxmox. But wanted to ask here as suspect you all have better ZFS knowledge. Just in case that makes a difference.
That said, will test it out for certain.
Output from smartctl
root@pve:~# smartctl -a -d areca,1/2 /dev/sg16
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.18-16-pve] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     ST31000521AS
Serial Number:    9WK0QXFA
LU WWN Device Id: 5 000c50 02679dbf2
Firmware Version: CCA3
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Mon Aug 12 15:14:12 2019 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  617) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 174) minutes.
Conveyance self-test routine
  1 Raw_Read_Error_Rate     0x000f   117   100   006    Pre-fail  Always       -       143405903
  3 Spin_Up_Time            0x0003   100   100   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       216
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always       -       620969
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       6513
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       205
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   084   084   000    Old_age   Always       -       16
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   048   045    Old_age   Always       -       38 (Min/Max 36/45)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       176
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       263
194 Temperature_Celsius     0x0022   038   052   000    Old_age   Always       -       38 (0 10 0 0 0)
195 Hardware_ECC_Recovered  0x001a   021   021   000    Old_age   Always       -       143405903
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6833 (184 186 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2785150624
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2490566038
SMART Error Log Version: 1
ATA Error Count: 16 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 16 occurred at disk power-on lifetime: 889 hours (37 days + 1 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 08 ff ff ff 4f 00      01:10:03.834  READ FPDMA QUEUED
  27 00 00 00 00 00 e0 00      01:10:03.834  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      01:10:03.833  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00      01:10:03.832  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      01:10:03.832  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 15 occurred at disk power-on lifetime: 889 hours (37 days + 1 hours)
  60 00 08 ff ff ff 4f 00      01:10:00.728  READ FPDMA QUEUED
  27 00 00 00 00 00 e0 00      01:10:00.728  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      01:10:00.727  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00      01:10:00.726  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      01:10:00.726  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 14 occurred at disk power-on lifetime: 889 hours (37 days + 1 hours)
  60 00 08 ff ff ff 4f 00      01:09:57.598  READ FPDMA QUEUED
  27 00 00 00 00 00 e0 00      01:09:57.597  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      01:09:57.596  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00      01:09:57.595  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      01:09:57.595  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 13 occurred at disk power-on lifetime: 889 hours (37 days + 1 hours)
  60 00 08 ff ff ff 4f 00      01:09:54.475  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00      01:09:54.466  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00      01:09:54.458  READ FPDMA QUEUED
  27 00 00 00 00 00 e0 00      01:09:54.458  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 12 occurred at disk power-on lifetime: 889 hours (37 days + 1 hours)
  60 00 80 ff ff ff 4f 00      01:09:48.048  READ FPDMA QUEUED
  60 00 80 ff ff ff 4f 00      01:09:48.040  READ FPDMA QUEUED
  60 00 80 ff ff ff 4f 00      01:09:42.755  READ FPDMA QUEUED
  60 00 80 ff ff ff 4f 00      01:09:42.746  READ FPDMA QUEUED
  60 00 80 ff ff ff 4f 00      01:09:37.413  READ FPDMA QUEUED
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Have you tried putting your areca settings for smartctl in the "S.M.A.R.T. Extra Options" for each disk attached to the card?
By the way, in case you didn't notice, that's a very unhealthy disk you have there...
