- Nov 25, 2013
Hi, all,
after the disaster with the DOA WD drives I successfully replaced all disks of our small NAS.
Reference: https://forums.freenas.org/index.php?threads/wd-red-drives-not-spinning-up.25111/
Now, just one day later, I notice this - could someone please help me interpret the output? Should I suspect the connector in the enclosure or the controller?
APM set to 254 for all drives.
Thanks,
Patrick
Thanks,
Patrick
(ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 50 c1 82 40 ba 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 50 c1 82 00 ba 00 00 08 00 (ada2:ahcich2:0:0:0): Retrying command (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 10 40 5c 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 40 5c 99 00 d8 00 00 10 00 (ada2:ahcich2:0:0:0): Retrying command ... da2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 10 40 5c 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 48 5c 99 00 d8 00 00 10 00 (ada2:ahcich2:0:0:0): Error 5, Retries exhausted ... ahcich2: Timeout on slot 29 port 0 ahcich2: is 00000000 cs 20000000 ss 00000000 rs 20000000 tfd c0 serr 00000000 cmd 0000fd17 ahcich2: Error while READ LOG EXT (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 20 91 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 00 () (ada2:ahcich2:0:0:0): RES: 00 00 00 00 00 00 00 00 00 00 00 (ada2:ahcich2:0:0:0): Retrying command (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 20 91 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 20 91 99 00 d8 00 00 08 00 (ada2:ahcich2:0:0:0): Retrying command ... (ada2:ahcich2:0:0:0): READ_DMA48. ACB: 25 00 50 a5 99 40 d8 00 00 00 08 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 51 40 50 a5 99 00 d8 00 00 00 00 (ada2:ahcich2:0:0:0): Error 5, Retries exhausted (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 20 c8 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 20 c8 99 00 d8 00 00 08 00 (ada2:ahcich2:0:0:0): Retrying command ... (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 20 c8 99 40 d8 00 00 00 00 00 (ada2:ahcich2:0:0:0): CAM status: ATA Status Error (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) (ada2:ahcich2:0:0:0): RES: 41 40 20 c8 99 00 d8 00 00 08 00 (ada2:ahcich2:0:0:0): Error 5, Retries exhausted ...
[root@freenas-je] ~# zpool status
pool: zfs
state: ONLINE
scan: scrub in progress since Mon Dec 8 09:02:31 2014
790G scanned out of 4.99T at 309M/s, 3h58m to go
152K repaired, 15.45% done
NAME STATE READ WRITE CKSUM
zfs ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0 (repairing)
ada3p2 ONLINE 0 0 0
errors: No known data errorsCode:
[root@freenas-je] ~# smartctl -a /dev/ada2
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p12 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST4000VN000-1H4168
Serial Number: Z302C6XN
LU WWN Device Id: 5 000c50 079481ce9
Firmware Version: SC44
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5900 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Dec 8 09:50:37 2014 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 107) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 531) minutes.
Conveyance self-test routine
SCT capabilities: (0x10bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 115 092 006 Pre-fail Always - 90091760
3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 4
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 065 060 030 Pre-fail Always - 3616389
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 89
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 4
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 139
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 1
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 065 045 Old_age Always - 34 (Min/Max 31/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 4
194 Temperature_Celsius 0x0022 034 040 000 Old_age Always - 34 (0 19 0 0 0)
197 Current_Pending_Sector 0x0012 100 099 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 099 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 139 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 139 occurred at disk power-on lifetime: 88 hours (3 days + 16 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 08 ff ff ff 4f 00 02:58:13.087 READ FPDMA QUEUED
60 00 38 ff ff ff 4f 00 02:58:13.086 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 02:58:13.064 READ LOG EXT
60 00 08 ff ff ff 4f 00 02:58:09.128 READ FPDMA QUEUED
60 00 38 ff ff ff 4f 00 02:58:09.127 READ FPDMA QUEUED
Error 138 occurred at disk power-on lifetime: 88 hours (3 days + 16 hours)
2f 00 01 10 00 00 00 00 02:58:09.093 READ LOG EXT
60 00 08 ff ff ff 4f 00 02:58:05.167 READ FPDMA QUEUED
60 00 38 ff ff ff 4f 00 02:58:05.166 READ FPDMA QUEUED
Error 137 occurred at disk power-on lifetime: 88 hours (3 days + 16 hours)
2f 00 01 10 00 00 00 00 02:58:05.133 READ LOG EXT
61 00 28 ff ff ff 4f 00 02:58:01.212 WRITE FPDMA QUEUED
60 00 08 ff ff ff 4f 00 02:58:01.212 READ FPDMA QUEUED
Error 136 occurred at disk power-on lifetime: 88 hours (3 days + 16 hours)
40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
60 00 38 ff ff ff 4f 00 02:58:01.211 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 02:58:01.134 READ LOG EXT
60 00 08 ff ff ff 4f 00 02:57:55.804 READ FPDMA QUEUED
Error 135 occurred at disk power-on lifetime: 88 hours (3 days + 16 hours)
60 00 38 ff ff ff 4f 00 02:57:55.796 READ FPDMA QUEUED
60 00 10 ff ff ff 4f 00 02:57:55.794 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 02:57:55.785 READ FPDMA QUEUED
60 00 18 ff ff ff 4f 00 02:57:55.782 READ FPDMA QUEUED
# 1 Conveyance offline Completed without error 00% 41 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
