Are E3-1200 v3 series CPUs interchangeable?
Robert Trevellyan
Pony Wrangler
Let's say you have a PowerEdge T20 that shipped with an E3-1225 v3. Is there anything that would prevent installation of any other CPU in that series? I know that BIOS support is required for hyper-threading, so some models would be underutilized unless the T20 BIOS happened to have HT support. I see that some models are designated low power, so maybe that wouldn't turn out well. What else could go wrong?
I found percentage chance of upgrade success listings on cpu-upgrade.com, which appear to be based on reports of compatibility with specific motherboards. Is there no way to know other than by getting a promise from the motherboard maker?
I looked for something in Intel's literature that might indicate whether processors in a series should be interchangeable, but I couldn't find anything. Wikipedia didn't seem to have the answer either. I feel like there's just some fundamental gap in my knowledge here.
Technically, no. Some OEMs (*cough* Sony *cough*) are known to have whitelists, though. Additionally, newer processors may require a newer BIOS, which may not be made available (Haswell Refresh, Broadwell).
Of course, if the current CPU is a low-TDP version, the motherboard may not be able to handle power distribution for a normal model.
I highly doubt any OEM would customize the BIOS at that level. Intel provides them with the framework for interfacing with the processor.
Touching on this, my HP Micro Server G8 had a pentium in it originally that was rated for 35W with the passive heatsink it comes with, i then installed a full fledged Xeon E3-1265LV2 which is rated for 45W....needless to say i installed a aftermarket heatsink (and good ole HP used a proprietary motherboard socket dimensions that arent exactly 1155...) so the aftermarket heatsink had to be modded a little bit...but it looks lovely!
To answer your question, i dont think it would be an issue...i would google around to see what others have changed the CPU out with especially if the motherboard can only handle a certain TDP
Robert Trevellyan
Pony Wrangler
I wasn't even thinking of being able to drop in an E3-1200 v4, but your comment led me to Wikipedia's statement that the LGA 1150 Broadwells were "Announced to be backward compatible with the LGA 1150 motherboards designed for Haswell processors."
I do remember being able to swap Socket 478 and LGA 775 CPUs around without any issues, but it's been a while. If I were an OEM, I would want to be able to ship a machine with whatever CPU made sense for the market at any point in time without having to build a different motherboard.
Good to know.
Thank you both for your input.
Robert Trevellyan
Pony Wrangler
According to Intel, the 1225 has the equal-highest TDP of all the E3-1200 v3 Xeons, so I guess power and cooling shouldn't be an issue.
