Apps don't start and "Installed Applications" screen loads indefinitely.
Truenas Scale 22.02.4
Apps Nextcloud, Pihole, Plex, Tailscale were running fine before.
Pools are all online and no errors from scrub or smart.
Please help.
That is the systemctl status k3s output:
Please help.
root@truenas[~]# systemctl status k3s ● k3s.service - Lightweight Kubernetes Loaded: loaded (/lib/systemd/system/k3s.service; disabled; vendor preset: disabled) Active: active (running) since Sat 2022-10-22 00:58:37 CEST; 8min ago Docs: https://k3s.io Process: 13714 ExecStartPre=/sbin/modprobe br_netfilter (code=exited, status=0/SUCCESS) Process: 13716 ExecStartPre=/sbin/modprobe overlay (code=exited, status=0/SUCCESS) Main PID: 13718 (k3s-server) Tasks: 45 Memory: 548.0M CGroup: /system.slice/k3s.service └─13718 /usr/local/bin/k3s server Oct 22 01:06:50 truenas k3s[13718]: E1022 01:06:50.133653 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:06:52 truenas k3s[13718]: E1022 01:06:52.130996 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:06:54 truenas k3s[13718]: E1022 01:06:54.133384 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:06:56 truenas k3s[13718]: E1022 01:06:56.131735 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:06:58 truenas k3s[13718]: E1022 01:06:58.132199 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:07:00 truenas k3s[13718]: E1022 01:07:00.133130 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:07:02 truenas k3s[13718]: E1022 01:07:02.131328 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:07:04 truenas k3s[13718]: E1022 01:07:04.132872 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:07:06 truenas k3s[13718]: E1022 01:07:06.132907 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2 Oct 22 01:07:08 truenas k3s[13718]: E1022 01:07:08.131391 13718 kubelet_volumes.go:245] "There were many similar errors. Turn up verbosity to see them." err="orphaned pod \"8e5c666c-4015-4e17-803d-0159c09da806\" found, but error not a directory occurred when trying to remove the volumes dir" numErrs=2
