Applications are not running
chri5
Check your date and times in the bios
Thank you! Just had a panic after installing a GPU which didn't go well. Ended up having to reset BIOS to get my system to boot. Going back and setting the right time in BIOS solved my apps not running issue.
flimofly
This fixed it for me.
Localization in the System Settings > General tab in the Truenas GUI had also been reset. But reconfiguring that alone did not fix the issue with the apps not running.
chan1600
i had the same issue, after upgrading to TrueNAS Scale 20.02.2
I have fixed the issue by deleting/renaming the following file:
$app_pool/ix-applications/k3s/server/token
For me this was at the following location:
/mnt/ssd/ix-applications/k3s/server/token
Hope this will help you with the issue.
Thank you. it works
spencerm
I tried renaming, and restarting but no joy, same error. node-token is a link to token. I expected it to recteate token on restart but it didn't. What am I missing?
