Thank you! Just had a panic after installing a GPU which didn't go well. Ended up having to reset BIOS to get my system to boot. Going back and setting the right time in BIOS solved my apps not running issue.
Localization in the System Settings > General tab in the Truenas GUI had also been reset. But reconfiguring that alone did not fix the issue with the apps not running.
I tried renaming, and restarting but no joy, same error. node-token is a link to token. I expected it to recteate token on restart but it didn't. What am I missing?
