snowmirage
- Sep 20, 2011
I get the impression from my searching there is no "easy" way to do this, but I am looking for a way to monitor the status of a service in FreeNAS 8. In my case I would eventually be able to pool the server using Nagios and to find out if CIFS and/or iSCSI are up and running.
I suspect i'll have to try to script something can anyone help identify processes to look for various services in FreeNAS8, or point me in the right direction I haven't seen it mentioned in the documentation I have read just that you can see the running processes by opening
"Display System Processes"
I suspect that "istgt" is the iSCSI process and that "smbd" is CIFS are there other processes I should watch for those services as well?
Thank you
-Snow
Thank you
-Snow
