Hi FreeNAS forum
Another FreeNAS+NFS+ESXI+Datastore performance problem.
Thanks for a great forum.
(sorry for my english, hope that you understand)
First of all, I have read the many threads about NFS Performance with VMWare, and I know and get that it is all related to the SYNC writes requested by VMWARE's NFS.
I have the following hardware
FreeNas-9.10 hardware
- Supermicro X9SRL-F
- Intel Xeon E5-2603 V2 - Box
- 96 GB DDR3-1866 ECC REG
- 8 x HGST Ultrastar 7K6000 4TB HDD 7200rpm SAS 128MB cache 24x7 12 Gb/s
- Intel DC P3500 PCI-e SSD 400 GB
- 10 Gbit Intel X520-DA2 E10G42BTDA - PCI Express 2.0 x8
- IBM M1015 (Cross flashing to a LSI9211-8i in IT Mode P20.00.07.00)
VMware Server
- HP DL385p gen8
- Esxi 6.5
10 Gbe Nic with direct cable from FreeNAS to 10 Gbe Vmware Nic.
(Works great - about 9400 mbit with iperf3 test)
All test with:
NIC:
MTU=9000 (FreeNAS + VMware)
ZFS:
Sync=standard
Compression=Off
Atime = Off
Test 1: - Performance test direct on the FreeNAS Server.
Raid Type: Mirror / Raid-10
HDD: 8 x HGST Ultrastar 7K6000 4TB HDD 7200rpm SAS 128MB
SLOG: N/A
CMD: dd if=/dev/zero of=temp.dat bs=4M count=50000
Write: 793 mb/s
CMD: dd if=temp.dat of=/dev/null bs=4M
Read : 790 mb/s
Test 2: - Performance test direct on the FreeNAS Server.
Raid Type: No raid only one SSD
HDD: 1 x Intel DC P3500 PCI-e SSD 400 GB (Speed 1000 mb/s write, 2200 Mb/S Read)
SLOG: N/A
Write: 907 mb/s
Read : 1149 mb/s
Test 1 and Test 2 - It's the speed I expect. - What do you think ?
Test 3 - Performance test - FreeBSD Server on VMware ESXI - "NFS FreeNAS Datastore"
SLOG: 1 x Intel DC P3500 PCI-e SSD 400 GB (Speed 1000 mb/s write, 2200 Mb/S Read)
Write: 365 mb/s
Read : 490 mb/s
Test 4 - Performance test - FreeBSD Server on VMware ESXI - "NFS FreeNAS Datastore"
SLOG: N/A
Write: 490 mb/s
Read : 493 mb/s
Test 3+4
- Does the performance look right to you ?
- Is it as you would expect ?
- Ideas for performance improvement ?
- Do you think my CPU is the problem ?
If I disable ZFS Sync everyting is great - But that not an OPTION !!!
Thanks for your help.!!
/Simon
VMware Server
- HP DL385p gen8
- Esxi 6.5
All test with:
NIC:
ZFS:
Sync=standard
Compression=Off
Atime = Off
SLOG: N/A
Write: 793 mb/s
Read : 790 mb/s
SLOG: N/A
Write: 907 mb/s
Read : 1149 mb/s
Write: 365 mb/s
Read : 490 mb/s
SLOG: N/A
Write: 490 mb/s
Read : 493 mb/s
Test 3+4
/Simon
