Another first build thread - Australia
sk1ba
Neophyte
Hi All,
Just hoping some kind folks on here would take a look over my build and make suggestions.
My budget is 2K and the below build is currently coming in at 1.8K so I have some wiggle room.
CPU:
AMD Ryzen 3 3200G
Motherboard:
MSI X470 GAMING PLUS MAX
Memory:
Corsair Vengeance LPX 16GB (2x8GB), PC4-24000 (3000MHz)
SSD (OS Drive)
Kingston 250GB SSD, A2000, M.2 2280 NVMe PCIe Gen3
HDD(Storage)
Seagate 4TB IronWolf NAS 3.5" Hard Drive, SATA III, 5900RPM, 64MB Cache, CMR
Case:
Fractal Design Define R5 Black ATX Case,
Power Supply:
Corsair 600W SF600
Wizened Sage
SSD (OS Drive)
HDD(Storage)
Case:
Power Supply:
Corsair 600W SF600
All fine
Memory:
ECC is best if you want to care about your data (which may be one of the reasony you selected ZFS/TrueNAS
Motherboard:
Gaming boards are rarely a good choice. If you must use it, be sure to disable all overclocking.
ASROCK RACK may have some kind of alternative available in your part of the world.
CPU:
AMD Ryzen 3 3200G
Be sure to look up C States and Power/Cool 'n' Quiet BIOS settings in the forum and set them all off/correctly or you'll have real problems using Ryzen.
ChrisRJ
Senior Member
For your budget I would go for used enterprise gear. It will likely even be cheaper and work better. I hadn't looked in this direction for a long time. But finally went with an old Supermicro board (X9SRi-F), which is more than sufficient. Could be more power-efficient, but the value for money (esp. DDR3 ECC RDIMMs) is great.
sk1ba
Neophyte
Thank you sretalla & ChrisRJ for your input - I guess its back to the drawing board and scanning of ebay to find some decent used enterprise gear!
Also ChrisRJ - the links in your signature are helpful and good reading :)
sk1ba
Neophyte
Thoughts on this build?
Supermicro Mini Tower 5029C-T Barebone
Intel CORE i3-9100F
Crucial 8GB PC4-21300R DDR4-2666 2 RDIMM
Crucial P2 250GB NVMe PCIe M.2 SSD
Seagate IronWolf 4TB NAS Hard Disk Drive HDD
NugentS
Senior Member
Still no ECC
However whats more important is What are you looking to achieve?
Etorix
Senior Member
I've never seen RDIMM without ECC… but RDIMM does not work with a i3-9100F.
You need (ECC) UDIMM with a i3-9100F, otherwise the build would be fine.
To use cheaper RDIMM, look for old Xeon E5 (Supermicro X9 generation) or Xeon D-1500 (X10SDV, but second-hand boards are rare).
NugentS
Senior Member
Actually, to my surprise the i3-9100F actually supports ECC.
When I was looking for something I used bargain hardware in the UK (is there anything similar in Aus?) to get the CPU and memory from but bought the motherboard new. I used 2nd hand Xeon with an X10SRi-F (from memory). Lots of SATA ports
However the most important thing is still what do you want to achieve? According to your build list you have:
  1. 8GB RAM (absolutely bare minimum)
  2. Single NVMe to boot from - OK - not resilient - but OK as a pilot / test system
  3. Single 4TB HDD - whats the point?
