L
LinearNetworking
Guest
I have a ZFS mirror 8 TB array running on a FreeBSD 8.2-RELEASE-p1
Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
FreeNAS-8.0-RELEASE-amd64 and one of my drives developed the "click of death" I have determined what drive it was and replaced it with IDENTICAL hardware
Now in the storage area i get Pool1 /mnt/Pool1 Error getting used space (Error) Error getting available space Error getting total space and looking at the logs at boot i have this error
The root drive is a 4 GB USB drive that is directly connected to the MoBo. When i try to go into the ZFS options i get "Sorry, an error occurred ZFS snapshots were set for every 2 hours for this was a high demand device that moved at least a TB of data back and forth every 6 hours
Am i screwed or is there a way to fix this"? This was a mirrored array so shouldn't the other drives have a copy of the ZFS log to be able to replicate the data?
root: /etc/rc.d/mountd: WARNING: /etc/exports is not readable. Aug 6 20:47:48 Cerebellum_I mountd[1195]: can't open /etc/exports Aug 6 20:47:48 Cerebellum_I root: /etc/rc: WARNING: failed precmd routine for vmware_guestd Aug 6 20:47:53 Cerebellum_I ntpd[1446]: ntpd 4.2.4p5-a (1) Aug 6 20:47:53 Cerebellum_I kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8 Aug 6 20:47:53 Cerebellum_I mountd[1196]: can't open /etc/exports Aug 6 20:47:54 Cerebellum_I mountd[1196]: can't open /etc/exports Aug 6 20:48:02 Cerebellum_I ntpd[1447]: time reset +0.803440 s Aug 6 20:48:11 Cerebellum_I mountd[1196]: can't open /etc/export
