Am I installing correctly?
GameOgre
I'm using FreeNAS for the first time. I have the flash drive prepared, and the NASbox connected to the router. I have no input device or monitor on the NASbox.
If I read the instructions right, once I plug in the flash drive and it boots, I should be able to connect to the webgui with just the IP address of the NAS box from my desktop, correct? Or am I missing something?
pirateghost
Unintelligible Geek
That's it, but you will need to know the IP address of the Nas box. If you can get it from your router, great. If not you need a monitor hooked up temporarily
Sent from my Nexus 5
GameOgre
Well the NAS box is not showing up in the client list of my router. The light is lit for it's connection port, but I guess they're not communicating?
What did I do wrong?
*edit*
Ok so I just hooked a monitor to it, booted, and it seems to be stuck on "mountroot>"
*edit 2*
Found the problem. I was getting an error 19. Did some reading and moved my usb drive from the 3.0 to a 2.0. Booted just fine.
