Allocating more reserve space on USB stick. (Slightly different size sticks)
diskdiddler
I discussed this somewhere recently and totally forgot, sorry.
Is this possible? I want to put in some 16gb sticks, I'm hoping to reserve out say an extra GB even, so that if a stick dies, FreeNAS is still happy with any other brands 16gb stick, despite minor size differences.
Can it be done for the USB boot sticks?
diskdiddler
Did you find the answer to this?
No, and I'm much closer to needing it too.
Also want to do the same for my dual SSD mirror. I think default is 2gb on hard drives? I'm ok losing 20.
diskdiddler
Anyone else? I want to do this to at least 4 of my drives (2 USb and 2 SSD)
pro lamer
Brainstorm style crazy idea:
  1. Create a virtual disk of a chosen small size
  2. Install FreeNAS onto it
  3. Do a byte by byte copy to the desired disk
Not sure how to fix the partition table anyway...
Sent from my mobile phone
diskdiddler
So the thing is, I've found in the menu for FreeNAS to configure it to have a larger swap allocation per disk.
I do not know if SWAP = reserved space?
I do not want swap, on my USB keys, period.
Even if swap is only reserved and it won't thrash my USB key, the USB key is made, according to a post I read, once you configure a larger than stock swap, it will only apply, to new pools you create. Clearly the boot pool itself, isn't going to be new.
So not sure of a solution.
pro lamer
Another idea:
  1. For the sake of the example let's assume you have a small boot pool (virtual or real disks) eg 16GB
  2. Disable automatic pool growth for the boot pool
  3. Attach the bigger sized disk as a mirror (eg240GB) (beware that 3-way mirrors were found not possible for boot pools in our forums this year, I can't remember who exactly had that try)
  4. If it works you have 224GB free
  5. Then You may try replacing the small drive with a bigger one or creating some partitions/slices...
pro lamer
Or to be more accurate with your SSD example:
  1. Let's assume you have a physical 128 GB SSD and want to be ready for 120GB sized SSDs
  2. Run a VM
  3. Install FreeNAS to a virtual 119GB disk
  4. Disable automatic pool growth
  5. Attach your physical 128GB SSD as a mirror
  6. Detach the virtual disk
  7. Leave of the VMs
  8. Use your physical SSD in a physical environment...
diskdiddler
This is a crazy way to have to do this, to be fair :/ the software should support it properly I would say.
