SOLVED All SAS disks aren't displaying their serial number in the webui
regnock
I'm running the current stable version of 9.10. Currently none of my SAS disks are displaying their serial numbers in the webui. My two SSD and two NVME devices are reporting them correctly. All the problem drives are hanging off a AVAGO MegaRAID SAS controller.
Also possibly related. I added descriptions to all of these disks and they didn't survive after my web session.
I have attached a screenshot, that shows the missing serial numbers. Those descriptions are now gone also.
Is this a known issue?
Jailer
Not strong, but bad
Which specific model and what firmware version?
Arwen
Maybe bad news. The MegaRAID is not a HBA, (Host Bus Adapter), if I recall this correctly.
Thus, you may not get SMART data from the drives either. And ZFS may not beable to cause
a SAS / SCSI block sparing.
But, as @Jailer asked, please supply the model of the Avago / LSI card.
regnock
Thanks for the replies.
The controller is a LSI MegaRAID 9361-8i SAS 12Gb/s PCIe 3.0 8-Port Controller with 1GB Cache
Here is the relevant snippet from dmesg which contains the firmware version:
mfi0: 359019 (533784522s/0x0020/info) - Shutdown command received from host
mfi0: 359020 (boot + 10s/0x0020/info) - Firmware initialization started (PCI ID 005d/1000/9361/1000)
mfi0: 359021 (boot + 10s/0x0020/info) - Firmware version 4.290.00-4536
mfi0: 359022 (boot + 13s/0x0008/info) - Battery Present
mfi0: 359023 (boot + 13s/0x0020/info) - Package version 24.9.0-0022
mfi0: 359024 (boot + 13s/0x0020/info) - Board Revision 11A
mfi0: 359025 (boot + 18s/0x0008/info) - Battery charge complete
mfi0: 359026 (boot + 18s/0x0008/info) - Battery temperature is normal
mfi0: 359027 (boot + 32s/0x0004/info) - Enclosure (SES) discovered on PD 23(c Port 0 - 3/p1)
mfi0: 359028 (boot + 32s/0x0004/info) - Enclosure (SES) discovered on PD 08(c Port 0 - 3/p2)
mfi0: 359029 (boot + 32s/0x0004/info) - Enclosure (SES) discovered on PD 2a(c Port 4 - 7/p1)
mfi0: 359030 (boot + 32s/0x0004/info) - Enclosure (SES) discovered on PD 09(c Port 4 - 7/p2)
mfi0: 359031 (boot + 32s/0x0004/info) - Enclosure PD 08(c Port 0 - 3/p2) communication restored
mfi0: 359032 (boot + 32s/0x0004/info) - Redundant enclosure EMM PD 09(c Port 4 - 7/p2) inserted for EMM PD 08(c Port 0 - 3/p2)
mfi0: 359033 (boot + 32s/0x0004/info) - Enclosure PD 09(c Port 4 - 7/p2) communication restored
mfi0: 359034 (boot + 32s/0x0004/info) - Enclosure PD 23(c Port 0 - 3/p1) communication restored
mfi0: 359035 (boot + 32s/0x0004/info) - Redundant enclosure EMM PD 2a(c Port 4 - 7/p1) inserted for EMM PD 23(c Port 0 - 3/p1)
mfi0: 359036 (boot + 32s/0x0004/info) - Enclosure PD 2a(c Port 4 - 7/p1) communication restored
mfi0: 359037 (boot + 32s/0x0002/info) - Inserted: Encl PD 08
ses0 at mfi0 bus 0 scbus0 target 8 lun 0
ses0: <LSI SAS2X28 0e12> Fixed Enclosure Services SPC-3 SCSI device
ses0: Serial Number
ses0: 150.000MB/s transfers
ses0: Command Queueing enabled
ses0: SCSI-3 ENC Device
ses1 at mfi0 bus 0 scbus0 target 9 lun 0
ses1: <LSI SAS2X28 0e12> Fixed Enclosure Services SPC-3 SCSI device
ses1: Serial Number
ses1: 150.000MB/s transfers
ses1: Command Queueing enabled
ses1: SCSI-3 ENC Device
ses2 at mfi0 bus 0 scbus0 target 35 lun 0
ses2: <LSI SAS2X36 0e12> Fixed Enclosure Services SPC-3 SCSI device
ses2: Serial Number
ses2: 150.000MB/s transfers
ses2: Command Queueing enabled
ses2: SCSI-3 ENC Device
ses3 at mfi0 bus 0 scbus0 target 42 lun 0
ses3: <LSI SAS2X36 0e12> Fixed Enclosure Services SPC-3 SCSI device
ses3: Serial Number
ses3: 150.000MB/s transfers
ses3: Command Queueing enabled
ses3: SCSI-3 ENC Device
ItsValium
Bummer, no real HBA like allready suggested, any chance you could exchange it for a real HBA?
SAS3... Good news is that you may be able to use it with the new software stack, which replaces mfi and does support direct-attach disks. Search the forums for how to use mrsas instead of mfi.
regnock
Switching the driver worked! I now see serial numbers and my custom descriptions appear to be sticking. Thanks for all the help.
Arwen
@Ericloewe, thanks for picking up that detail about the driver switch.
@regnock,
Please check to see if you can get SMART data from the drives. It should work now but there is a
saying, if you did not test it, it does not mean it will work.
regnock
@regnock,
I am getting SMART data from the drives now :)
FWIW, the new stack works with all LSI SAS3 controllers and with the SAS2308 - the latter might be interesting for vendor-locked cards with no IT firmware.
