I have a running system with AsRock C2750D4i..
I'm currently running 9 disks in a raidz1 configuration.
My media pool is almost full and I want to expand and also want to move data to a little more secure ( 12 disks in a raidz2 ) pool.
I had a SAS card sitting ready ( LSI 9211-8i ),
I purchased a SAS expander ( HP SAS expander )
and a case ( http://www.teknobiyotik.com/dark-servernet-4u-5x-fanli-20x-3-5-hdd-hot-swap-server-kasa.html - page is in Turkish but you could get the picture )
So I had a MB sitting also ( AsRock 775Dual-VSTA ) from old days..
I'm using my NAS in SilverStone's DS380, 8 disks attached to the HDD racks, one dangling, 2 SSD drives are for jail.. So it's actually really cramped but it works without problem for nearly two years...
I put the LSI in the case and used an internal to internal cable + internal to external adapter to make it external.
Installed the mainboard ( just screwed in the case and attached power ). Put the expander to only PCI-E slot on it.
Installed all disks to bottom three rows and attached to expander via U2 to SFF-8087 cables. When I power up the expander case there are three leds lit on expander. I think three for every cable and one for the power.
Anyway, after that attached the external to external cable ( SFF-8088 to SF-8088 )...
Now I'm stumped. Because while FreeNAS shows the LSI card:
and also shows in mpsutil
as you can see there are no disks nor expanders.. So if we are sure that the cables are working, what could be the problem?
# dmesg
. . mps0: <Avago Technologies (LSI) SAS2008> port 0xd000-0xd0ff mem 0xdf7c0000-0xdf7c3fff,0xdf780000-0xdf7bffff irq 16 at device 0.0 on pci1 mps0: Firmware: 19.00.00.00, Driver: 21.01.00.00-fbsd mps0: IOCCapabilities: 185c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,IR> . .
# mpsutil show all
Adapter: mps0 Adapter: Board Name: SAS9211-8i Board Assembly: H3-25250-01D Chip Name: LSISAS2008 Chip Revision: ALL BIOS Revision: 7.37.00.00 Firmware Revision: 19.00.00.00 Integrated RAID: yes PhyNum CtlrHandle DevHandle Disabled Speed Min Max Device 0 N 1.5 6.0 SAS Initiator 1 N 1.5 6.0 SAS Initiator 2 N 1.5 6.0 SAS Initiator 3 N 1.5 6.0 SAS Initiator 4 N 1.5 6.0 SAS Initiator 5 N 1.5 6.0 SAS Initiator 6 N 1.5 6.0 SAS Initiator 7 N 1.5 6.0 SAS Initiator Devices: B____T SAS Address Handle Parent Device Speed Enc Slot Wdt Enclosures: Slots Logical ID SEPHandle EncHandle Type 08 500605b001bdd9c4 0001 Direct Attached SGPIO Expanders: NumPhys SAS Address DevHandle Parent EncHandle SAS Level
