Perhaps this may be a procedure thing, but 9.10 doesn't seem to be obtaining an IP address from my router unless I reboot the entire server...
Steps in 9.3:
1. Install jail plugins (doesn't matter what plugin).
2. Set jail config to DHCP.
3. Access router config and do one of the following (either worked just as well):
a) allow the jail to pull an IP from router
b) add entry to DHCP reservation list
c) change auto IP address to desired IP address within DHCP Reservation Table
4. Go to Jails tab, select desired Jail and click the "restart" button. (Jail restarts and successfully runs under my desired IP address.)
However, in 9.10, whenever I restart the jail, it never seems to access the DHCP in the router to get an IP. The only way I was able to get an IP for the jails is to copy and paste the MAC and "manually" add an entry into the DHCP Res Table. And even then, the only way I can get the Jail to pick up the address is to reboot the entire server...
Now I will say that this is not a big thing, as I'm a single home with only a few family users, so maintenence and some down time to reboot is NOT a big deal for me at all... But who knows whoever else out there mught be having the same problem or if there may actually be something wrong...
(Also, please forgive me if I haven't updated the FreeNAS version in my signature, but I'm at a Bowling League for my son at the moment, but I did manually check for an update as of last night and I'm at the latest 9.10 install...)
Edit: showed the post to my better half to read and she made me correct some smelling pisstakes...
Steps in 9.3:
