this is what i see from ISCIS using FreeNAs:
2018-03-27T14:13:06.435Z cpu3:66536)WARNING: ScsiPath: 4399: The Physical block size "65536" reported by the path vmhba64:C1:T0:L1 is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.435Z cpu20:70089)WARNING: ScsiDeviceIO: 6462: The Physical block size "65536" reported by the device naa.6589cfc000000105b9d5a244d16123ac is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.561Z cpu3:66536)WARNING: ScsiPath: 4399: The Physical block size "16384" reported by the path vmhba64:C1:T0:L2 is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.561Z cpu20:70089)WARNING: ScsiDeviceIO: 6462: The Physical block size "16384" reported by the device naa.6589cfc000000e24c9affb92d101faab is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.562Z cpu3:66536)WARNING: ScsiPath: 4399: The Physical block size "16384" reported by the path vmhba64:C1:T0:L2 is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.562Z cpu20:70089)WARNING: ScsiDeviceIO: 6462: The Physical block size "16384" reported by the device naa.6589cfc000000e24c9affb92d101faab is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.583Z cpu3:66536)WARNING: ScsiPath: 4399: The Physical block size "16384" reported by the path vmhba64:C1:T0:L2 is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.583Z cpu20:70089)WARNING: ScsiDeviceIO: 6462: The Physical block size "16384" reported by the device naa.6589cfc000000e24c9affb92d101faab is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.585Z cpu3:66536)WARNING: ScsiPath: 4399: The Physical block size "16384" reported by the path vmhba64:C1:T0:L2 is not supported. The only supported physical blocksizes are 512 and 4096
2018-03-27T14:13:06.585Z cpu20:70089)WARNING: ScsiDeviceIO: 6462: The Physical block size "16384" reported by the device naa.6589cfc000000e24c9affb92d101faab is not supported. The only supported physical
is there any way to correct these?
