After 11.2 upgrade, plex plugin crashes after a few days and now my HDD indicator is more active than usual.
Estropelic
Looks like temps are ok but more active than ever. Do I have to redo my plugins for 11.2 for more stability or are there any other users having the same issues since the upgrade?
D
dlavigne
Guest
Hard to tell if its a plugin issue or a hardware issue or something else... Anything in /var/log/messages around the time of the crash?
Yorick
Running a plex plugin in 11.2 for months now, rock solid. You'll need to dig to find root cause, it isn't as simple as "11.2 hates Plex".
Plex 1.14.1.5487 on 11.2-U1. Did have to rename the jail for the automated update process to work.
Estropelic
Came home today to see my HDD indicator light having a party. Seems like it might be a plugin issue. I stopped each plugin one at a time and things went back to normal. I have yet to reinstall my plugins using the new plugin manager. Any ideas folks?
Edit: Forgot to mention I left Plex running. I'm going to start one plugin at a time and see which ones the culprit.
I'm running the following plugins:
PLEX
SONARR
COUCHPOTATO
HEADPHONES
SABNZBD
