tak21
- Oct 11, 2012
solved - AFP works - sometimes (!?) - need help to get it stable
My freenas server is used to serve the MACs at home as tm-backup and fileserver.
But there are times, when I have no access to the server. As an example today, right after reboot. No access (11-10 21:36).
And then it starts to work again (12-10 01:06). And beside from what I just described the system tends to stop on a regular base (stop= no access at all via any protocol).
What can I do to get a stable system? (And please let me know, if more info’s are required!)
/var/log/messages
View attachment messages.txt
System Information
Hostname minisrv.local
Build FreeNAS-8.3.0-RC1-x64 (r12617)
Platform Intel(R) Atom(TM) CPU N2800 @ 1.86GHz
Memory 8159MB
System Time Fri Oct 12 01:17:34 CEST 2012
Uptime 1:17AM up 4:35, 1 user
Load Average 0.09, 0.10, 0.08
Connected through minisrv
/var/log/messages
System Information
Memory 8159MB
- user "share" has full access to all three zfs datasets used for sharing (1. timemachine, 2. data, 3. sw-mac)
- user "share" is used as guest access user in the afp service set up
- all shares were set up with the following parameters (except tm - this share has the discovery mode tm)
Name [ *** ] Share Comment [ *** - AFP share ] Path [ /mnt/tank/*** ] Allow List [ share ] Read-write Access [ share ] Disk Discovery [ x ] Disk discovery mode [ Default ] Cache CNID [ x ] Enable .AppleDouble [ x ] Default file permission ow gr oth read x x x write x x execute x x x Default directory permission ow gr oth read x x x write x x execute x x
