AFP - error when creating share
stadlereric
Hello all, i am new to the freenas community and this is my first post. Hopefully this issue has not been discussed yet. i see a lot of AFP discussion but nothing similar to what i'm running into. first off, thanks for taking the time to help me out.
I believe the issue i'm having is self-inflicted, and not the result of a freenas issue. I recently upgraded from 9.2.1.5 to the 9.2.1.6 beta because i could not get the cifs service to stop (that is fixed now).
when i did the upgrade through the gui i did not disable any of the services doh!
I am able to open the "Add Apple (AFP) Share" window but after i click ok this is what i get (screenshot attached.
Before I upgraded AFP was working like a champ along with everything else. Timemachine with both my macbook pro and the wife's mba worked great. I have been just living without AFP for a while now, and i don't remember exactly how i got to where i am now. i have no AFP shares configured.
The AFP share i'm trying to add is not a dataset shared with another protocol. My CIFS and NFS shares are separate datasets.
Thanks in advance,
Eric
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org that includes that traceback and post the issue number here.
stadlereric
Thank You dlavigne. I finally got around to creating a bug Id for this issue.
Issue #5321 created.
stadlereric
I received a reply that the issue was resolved in 9.2.1.6 RC. I re-created the issue with 9.2.1.6 RC and that is what I used to create the bug ID. The top half of the response is below. If the issue was resolved i wouldn't have been able to recreate it with that version. It is a low priority as far as i'm concerned, and thank you for all your hard work on this project.
Issue #5321 has been updated by Josh Paetzel.
  • Status changed from Unscreened to Closed
  • Seen in changed from 9.2.1.5-RELEASE to 9.2.1.6-BETA
This was fixed with 5719170480fc17203b8bf309dbdad5a9c29ef918 dc74b8cea62714809cc4df73fbb6bb9b453d1d60 and e169d0f43dd5a9c982576e941b5f071194bd30da which happened after the version you are running. The RC has the changes in it.
Bug #5321: AFP - error when creating share
  • Author: Eric Stadler
  • Status: Closed
  • Priority: Normal
  • Assignee: Josh Paetzel
  • Category: AFP
  • Target version: 9.2.1.6-RELEASE
  • Seen in: 9.2.1.6-BETA
Environment:
Software Version: FreeNAS-9.2.1.6-BETA-e57badf-x64
Request Method: POST
Request URL: https://19.1.2.250/admin/sharing/afp_share/add/
stadlereric
This issue was resolved in the latest release of 9.2.1.6 for me.
