AFP and LDAP not working
DaveY
Hi all,
Has anyone gotten afpd (time machine) to authenticate with a LDAP user on FreeNAS 9.3? I can't seem to mount an afpd disk unless the user is a local FreeNAS user. I also don't see any error messages on FreeNAS. From the Mac machine, it just fails and prompts you again for username/password
/var/log/messages just shows:
afpd[99825]: AFP statistics: 0.52 KB read, 0.38 KB written
No errors, nada.
I verified the user exists with getent passwd:
timemachine:*:3333:3333:Time Machine:/dev/null:/bin/false
Searching the forum, this was supposedly fixed/incorporated since 8.0.3 Any ideas??
D
dlavigne
Guest
If you don't get an answer, create a bug report at bugs.freenas.org and post the issue number here. If you're on 9.3, use the Support tab to create the report as it will include a debug file containing your build version, logs, and config files. Note that you have to first create an account at bugs.freenas.org before using the Support tab.
