Hey all,
Hopefully its a quick one. I have been reading a lot about jails and understand with 11.6 this is something that i will need to go with.
I have a fresh freenas, just burning in the kit and getting my resources ready to start setting it up. Storage side i believe is all sorted.
next i want to set-up the following:
1. Some sort of tool to download shows/movies/music
2. VPN client to route through my downloads. I am planning to use NordVPN or Private Internet Access
3. VPN client to access back into my NAS remotely. (would it be different from 2?)
4. Auto searcher/scarper for movies/shows i heard there are a few out there.
5. Auto rename tool
6. Media library management tool. (Plex? or something else)
Could you kindly suggest which ones i should go ahead with currently as most of the topics i read are form 3-4 years ago, wonder which ones are still well supported.
In which order should i set them up? Possibly there is a few guides you could recommend.
I know there will be a stack of issues with permissions if i make mistakes, i want to read the whole thing before i start setting up.
Any and all help would be much appreciated!
5. Auto rename tool
