Advice Needed for zvol
alex992
Can I expand Zvol on running live vm's ESXi storage, or I need to stop all vms before. Running TrueNAS 12.0-U1
Thank you
HoneyBadger
actually does care
Administrator
Yes, you can expand them live regardless of whether the ZVOL is a VMFS or RDM. Stopping VMs is not necessary but minimizing I/O is good practice (eg: do not actively be performing svMotion or snapshot consolidation)
Ensure that you rescan HBAs from the ESXi host after expanding the ZVOL and you should then see the new size. If you do not see the new drive size after a rescan, edit the ZVOL comment field from TrueNAS and save it, then rescan again.
