administrator user disabled
korralov
Since I have configured the active directory of W2016 in freeNAS, after 24 hours the administrator user is disabled. Re-enabling it from the Active Directory console resolves the problem, but it is recurring.
Attached configuration screenshots of active directory with FreeNAS
korralov
Every day at 3:00
Jan 26 03:30:02 freenas /cachetool.py: [common.freenasusers:335] Directory Users could not be retrieved: {'desc': 'Invalid credentials', 'info': '80090308: LdapErr: DSID-0C09042A, comment: AcceptSecurityContext error, data 533, v3839'}
File "/usr/local/www/freenasUI/common/freenasusers.py", line 332, in __init__
self.__users = dir(**kwargs)
File "/usr/local/www/freenasUI/common/freenasldap.py", line 2598, in __init__
super(FreeNAS_ActiveDirectory_Users, self).__init__(**kwargs)
File "/usr/local/www/freenasUI/common/freenasldap.py", line 2469, in __init__
super(FreeNAS_ActiveDirectory, self).__init__(**kwargs)
File "/usr/local/www/freenasUI/common/freenasldap.py", line 1578, in __init__
self.set_servers()
File "/usr/local/www/freenasUI/common/freenasldap.py", line 1734, in set_servers
self.dchandle.open()
File "/usr/local/www/freenasUI/common/freenasldap.py", line 340, in open
raise e
File "/usr/local/ww
Jan 26 03:30:02 freenas /cachetool.py: w/freenasUI/common/freenasldap.py", line 329, in open
res = bind_method()
File "/usr/local/www/freenasUI/common/freenasldap.py", line 235, in _do_authenticated_bind
return self._handle.simple_bind_s(self.binddn, self.bindpw)
File "/usr/local/lib/python3.6/site-packages/ldap/ldapobject.py", line 421, in simple_bind_s
resp_type, resp_data, resp_msgid, resp_ctrls = self.result3(msgid,all=1,timeout=self.timeout)
File "/usr/local/lib/python3.6/site-packages/ldap/ldapobject.py", line 715, in result3
resp_ctrl_classes=resp_ctrl_classes
File "/usr/local/lib/python3.6/site-packages/ldap/ldapobject.py", line 722, in result4
ldap_result = self._ldap_call(self._l.result4,msgid,all,timeout,add_ctrls,add_intermediates,add_extop)
File "/usr/local/lib/python3.6/site-packages/ldap/ldapobject.py", line 309, in _ldap_call
reraise(exc_type, exc_value, exc_traceback)
File "/usr/local/lib/python3.6/site-packages/ldap/compa
Jan 26 03:30:02 freenas /cachetool.py: t.py", line 42, in reraise
raise exc_value
File "/usr/local/lib/python3.6/site-packages/ldap/ldapobject.py", line 293, in _ldap_call
result = func(*args,**kwargs)
ldap.INVALID_CREDENTIALS: {'desc': 'Invalid credentials', 'info': '80090308: LdapErr: DSID-0C09042A, comment: AcceptSecurityContext error, data 533, v3839'}
anodos
Sambassador
Every day at 3:00
self.set_servers()
raise e
File "/usr/local/ww
res = bind_method()
raise exc_value
Every day at 3:00
self.set_servers()
raise e
File "/usr/local/ww
res = bind_method()
raise exc_value
Try turning off the directory service cache.
