panzerscope
- May 30, 2022
Hello Guys,
I know that right now on TrueNas Scale that there is no offering in the GUI to adjust the login timout period whereby the GUI ends your sesstion after a short while. Upon searching on Google I cam across the following command
sed -i 's/auth.generate_token",\[300/auth.generate_token",\[3600/g' /usr/share/truenas/webui/*.js
Is this still applicable or OK to use ?
Thanks,
P
Thanks,
P
