Jon Telfer
- May 7, 2014
I have an HP microserver with two WD red 3tb disks currently sitting mirrored.
I have a third WD red 3tb disk which I'd like to add to the mirror. Though the third drive is visible in the gui, it doesn't appear to allow this unless I add a fourth drive to create a mirrored mirror. I can see command line options in example 4-5 here http://docs.oracle.com/cd/E19253-01/819-5461/6n7ht6qvl/index.html which look to do what I'm after.
System is recently upgraded to 11 which I think is behind the upgrade notes in the zpool status.
Is this a good idea? Am I going to break everything?
Thanks for any help.
Jon
[root@freenas ~]# zpool status keith pool: keith state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: resilvered 12K in 0h0m with 0 errors on Fri Jun 30 20:51:06 2017 config: NAME STATE READ WRITE CKSUM keith ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/cf3d2cc4-f02a-11e4-b765-3464a99aff78 ONLINE 0 0 0 gptid/cfa49fa7-f02a-11e4-b765-3464a99aff78 ONLINE 0 0 0 errors: No known data errors [root@freenas ~]#
Jon
