Added a failing drive into my pool
sharpie
I had my FreeNAS up and running just how I wanted it with no problems at all with 500 GB or space. I found a HDD that wasn't being used and I wanted more space so I added it into my system and I chose to make it and extended part of my other 500 GB drive so it would show up as 1 TB. Little did I know that this drive was having problems and it always disconnects itself and doesn't reconnect. I started messing around and I think I have totally screwed eveything up because I detached the entire 1 Tb drive from inside my WebGui and when I try to reimport it doesn't work. All I want is to have the data off of my first drive.
When I do zpool status it says
no pools available
When I do zpool import it says
 pool: Storage
  state: DEGRADED
action: The pool can be imported despite missing or damaged devices.  The
        fault tolerance of the pool may be compromised if imported.
        Storage                                        DEGRADED
          gptid/6b6441d3-fbcd-11e2-b227-001aa0131ac1    ONLINE
          replacing-1                                  DEGRADED
            gptid/dfd62f7f-fe34-11e2-b227-001aa0131ac1  ONLINE
            17404100182605577821                        UNAVAIL  cannot open
Yeah, the disk you added by itself (gptid/6b6441d3-fbcd-11e2-b227-001aa0131ac1) is a stripe. If that disk fails, you lose EVERYTHING. Unfortunately for you, that disk is failing. What happens when you try to import the pool from the GUI? What error do you get?
sharpie
As in a auto import? It scans for things then shows up and has me select a volume, and then it says error: volume 'Storage' failed to import, for farther details check pool status
That's not too useful. Let me think for a few mins...
I'll send you a PM.
Brand
You should just be able to restore from your backup. Problem solved.
You are right.. you "should". Except he had no backups :(
