I had my FreeNAS up and running just how I wanted it with no problems at all with 500 GB or space. I found a HDD that wasn't being used and I wanted more space so I added it into my system and I chose to make it and extended part of my other 500 GB drive so it would show up as 1 TB. Little did I know that this drive was having problems and it always disconnects itself and doesn't reconnect. I started messing around and I think I have totally screwed eveything up because I detached the entire 1 Tb drive from inside my WebGui and when I try to reimport it doesn't work. All I want is to have the data off of my first drive.
When I do zpool status it says
When I do zpool import it says
no pools available
pool: Storage
state: DEGRADED
action: The pool can be imported despite missing or damaged devices. The
fault tolerance of the pool may be compromised if imported.
Storage DEGRADED
gptid/6b6441d3-fbcd-11e2-b227-001aa0131ac1 ONLINE
replacing-1 DEGRADED
gptid/dfd62f7f-fe34-11e2-b227-001aa0131ac1 ONLINE
17404100182605577821 UNAVAIL cannot open
