Add drive as hot spare?
Z300M
I know I can't expand a vdev after it's been created -- e.g., to increase the capacity or to change from RAIDZ1 to RAIDZ2 -- but can I add an identical drive as a hot spare?
herby
Bump
I'm curious about this too, and I can't find anything in the documentation about hot spares; except in the section about creating a new volume.
My motherboard only supports 4 SATA drives. I would like make a 3 disk raidz with a hot spare that can be pulled (from time to time) to free up a SATA port for backups.
ProtoSD
There's at least one ticket open about hot spares. I *think* I saw another ticket about some issue with FreeBSD that needed to be resolved before this could be fixed but I can't find it right now, I could be mistaken.
You can specify the spare drive(s) when you create a pool, or add them later. I think the only way you can add a hot spare in FreeNAS currently is to create the pool at the command line and specify your spare disks, then export the pool at the command line and import it using the GUI.
Here's a link to the Solaris docs on adding spares:
http://download.oracle.com/docs/cd/E19082-01/817-2271/gcvcw/index.html
danzg
I tried doing what you said -- added spare & exported pool in CLI.
But then FreeNAS wouldn't auto-import the pool -- said "volume already exists".
So in CLI I tried
# zpool import raid-5x3
cannot mount '/raid-5x3': failed to create mountpoint
cannot mount '/raid-5x3/alpha': failed to create mountpoint
Now,
# zpool status
  pool: raid-5x3
 state: ONLINE
 scrub: none requested
	raid-5x3    ONLINE       0     0     0
	  raidz1    ONLINE       0     0     0
	    ada1p2  ONLINE       0     0     0
	    ada2p2  ONLINE       0     0     0
	    ada4p2  ONLINE       0     0     0
	    ada5p2  ONLINE       0     0     0
	    ada3p2  ONLINE       0     0     0
	spares
	  ada0      AVAIL
errors: No known data errors
Console shows the volumes, but with "Used: None (Error)" and "Size: Error getting total space"
Also, in CLI:
# ls /mnt
./       ../      .snap/   md_size
Looks like my mounts are gone??
Help!
Have you tried rebooting then try auto-importing?
